So what Spark Plugs do YOU use.
Hey, i'm hoping to get an idea of what plugs people are running depending on their set-ups..
so list spark plug, code, company.. and mods... let's see how much this changes.
I run NGK Iridium's i don't have the code on me right now though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje »</TD></TR><TR><TD CLASS="quote">OEM NGK Platinums. don't know anything other than that, my friendly Honda dealer always knows for me
You Brits seem to have the right state of mind!
Factory NGK's for me too. I could only see changing the plug types for different motor setups ex. turbo,S/C, extreme allmotor. But even then I would only run NGK's or Denso's
</TD></TR></TABLE>You Brits seem to have the right state of mind!
bkr7e-11
And changed at least once a year.
Cheaper, better conductor... more cost effective way to keep the plugs in good health then running a set of plats into the ground.
Denso Iridiums for me .. instant gratification on these not-so-cheap plugs but worth the extra cash .. butt-dyno shows a feelable difference in torque and easier starts.
Mine is a 206whp n/a build up. 260psi on all 4 cyls, JUN3 cams, 2.5" T1R exhaust with Mugen TL muffler, JDM 4-1 header, Meziere electric water pump, etc. etc. etc ...
Modified by iperez at 6:59 PM 12/21/2006
NGK BKR6E in the winter and BKR7E in the summer (just regular old $1.89 copper plugs) with nothin but chevron 93 octane
ngk "blues" plug wires as well. nicest **** you can get
I use the OE NGK PFR6G-13, p/n 98079-56A7H
Yep, they are GS-R plugs.. not sure how I made that mixup after the research I did before buying them. No issues whatsoever, but I'll go with the smaller gap ITR plugs, PFR6G-11, p/n 98079-5614H next time.
Modified by 330R at 1:55 PM 12/21/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R »</TD></TR><TR><TD CLASS="quote">I use the OE NGK PFR6G-13, p/n 98079-56A7H
If I'm not mistaken (I don't have the boxes in front of me), the plugs you have listed are wrong. The ITR's should have a 1.1mm gap. The ones you have listed with the 13 in the number tell me that yours have a 1.3mm gap, which are correct for a B16 or a GSR motor.
</TD></TR></TABLE>If I'm not mistaken (I don't have the boxes in front of me), the plugs you have listed are wrong. The ITR's should have a 1.1mm gap. The ones you have listed with the 13 in the number tell me that yours have a 1.3mm gap, which are correct for a B16 or a GSR motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">
If I'm not mistaken (I don't have the boxes in front of me), the plugs you have listed are wrong. The ITR's should have a 1.1mm gap. The ones you have listed with the 13 in the number tell me that yours have a 1.3mm gap, which are correct for a B16 or a GSR motor.</TD></TR></TABLE>
I added to my prior post.
I see it now.
Just didn't want the wrong info out there.
</TD></TR></TABLE>I see it now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">bkr7e-11
</TD></TR></TABLE>+4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R »</TD></TR><TR><TD CLASS="quote">but I'll go with the smaller gap ITR plugs, PFR6G-11, p/n 98079-5614H next time. </TD></TR></TABLE>
the OEM platinum plugs over here i've got as 98079-5714H (PFR7G-11), is that just a different heat rating? would anybody mind highlighting the difference?
thank you
thank you
thank you
I'm pretty sure that number is the heat range. I just looked at my boxes and the 6 is correct for the US market. I wonder why yours are a 7?
thank you
</TD></TR></TABLE>I'm pretty sure that number is the heat range. I just looked at my boxes and the 6 is correct for the US market. I wonder why yours are a 7?
