Will this size fit?
I JUST BOUGHT SUM TIREZ 195/60/14 THE GUY SAID THEY WILL FIT ON MY 93 EG COUPE STOCK STANDARDS SAYS ITS 185/60/14 ....WILL I HAVE PROBLEMS LIKE RUBBING OR W.E SORT?
They will probably not rub, but they will make your speedometer and odometer read low by 2.1 percent.
I wouldn't buy oversized tires, but if you already bought them - especially if they came on a set of wheels, so they're basically free - then just use them up, and then go back to the proper size tires when you need to buy more.
P.S.
P.S.
the O.D. (overall diameter) on a 185/60R14 is 22.80 inches...the O.D. on a 195/60R14 is 23.30 inches... so yea i will fit and you should have any problems except maybe your speedometer being off about 3-5mph... all this is assuming no lowering... you may or maynot have issues after lowering...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 »</TD></TR><TR><TD CLASS="quote">your speedometer being off about 3-5mph...</TD></TR></TABLE>
You mean, at 144-241 miles per hour?
Sounds like you didn't bother reading the previous post, just above yours...
