need help removing paint?
Old Dec 20, 2006 | 10:19 PM
dylokjai's Avatar
Default need help removing paint?
I need help/ideas n how to remove the black spray paint people used on there tail lights? or should i just go to the junk yard for a used set
Old Dec 20, 2006 | 10:25 PM
bokals's Avatar
Default Re: need help removing paint? (dylokjai)
paint thiner, give it a shot?
Old Dec 20, 2006 | 11:00 PM
lxaccord51oxl's Avatar
Default Re: need help removing paint? (Element.)
or acetone. or the paint remover the ladies use to remove their nail polish. or you can try wet sanding it off, but u gota have patience. but after its all done, polish it to remove the scratches. no need to buy a new one..heh
Old Dec 22, 2006 | 01:10 PM
dylokjai's Avatar
Default Re: need help removing paint? (lxaccord51oxl)
non of the above work!
if use aircraft paint remove will that work and will that damage the shine from the plastic?
Old Dec 22, 2006 | 01:25 PM
Hondizzle!'s Avatar
I think your best bet would be to sand it off with some 600 grit and then once you get all the paint off... start the polishing process to get the shine back. If you use a thinner type material strong enough to take the paint off it will more than likely ruin the finish anyway. If it all sounds like to much work to you... go junkyard hoppin
Old Dec 22, 2006 | 02:27 PM
__oversea's Avatar
wet send and polish
Old Dec 22, 2006 | 02:31 PM
Hondizzle!'s Avatar
Default Re: need help removing paint? (FourMotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourMotion &raquo;</TD></TR><TR><TD CLASS="quote">wet send and polish</TD></TR></TABLE>
mos def
Old Dec 22, 2006 | 03:24 PM
or paint thinner
Old Dec 22, 2006 | 03:28 PM
B_CRUZ!'s Avatar
oven cleaner the bitch and wetsand it to a shine with 1500 and rubbing compound.
captain_crunch
Paint and Body
Dec 3, 2007 08:50 AM
vietintegboi
Nov 14, 2006 12:56 PM
rufridn
Jan 18, 2006 08:05 PM
DJNauTicz
Feb 22, 2005 08:17 PM
