water pump bolt
Old Dec 20, 2006 | 04:52 PM
syvikraicer's Avatar
Default water pump bolt
i need some opinions. i broke 1 bolt (upper left bolt) when screwing in one of the bolts that holds the water pump. i used a torque wrench set at 8.5 lbs-ft and that some bitch broke. should i be worried about a leak?
Old Dec 20, 2006 | 05:25 PM
Archidictus's Avatar
Unceasing Measure
Default Re: water pump bolt (syvikraicer)
Yes you should. Remove the damaged bolt and put a new one in.
user 23852445234524
Honda CR-V & Element
Apr 16, 2016 05:35 PM
DevineEntity
Aug 22, 2006 03:46 AM
gnar kill
Mar 29, 2005 01:14 PM
abolish415
May 20, 2004 10:36 AM
