LS-Turbo, should I switch to a VTEC tranny?
Old Dec 20, 2006 | 04:49 PM
Kyoto now's Avatar
Default LS-Turbo, should I switch to a VTEC tranny?
I'm just about ready to turbo my LS but I'm curious if a VTEC tranny would help or hinder. I had a YS1 on my all motor B20 Integra and it was cool, except for 5th gear cruising speeds. How would a VTEC trans affect daily driving in a 250whp Integra? Thanks.
Old Dec 20, 2006 | 05:04 PM
IHTFP's Avatar
Default Re: LS-Turbo, should I switch to a VTEC tranny? (DA9 Purist)
shorter gears would make it faster
but youd have a higher cruising speed..
just imagine your old b20 but now w/ 250whp
Old Dec 20, 2006 | 05:06 PM
lVlemphizStylez's Avatar
Default Re: LS-Turbo, should I switch to a VTEC tranny? (IHTFP)
traction may become an issue...But if you got the right rubber and suspension youll be fine
Old Dec 20, 2006 | 05:24 PM
Kyoto now's Avatar
Default Re: LS-Turbo, should I switch to a VTEC tranny? (lVlemphizStylez)
what should I consider when upgrading the suspension?
Old Dec 20, 2006 | 05:37 PM
Ah I'd be BSing if I tried to answer that question as I've been riding on stock suspension since 2000 (quarter mile racing with the rocking of the whole car = P )...Try the drag racing forum for tips on that one...I know traction bars are out there for the teg and that would definately help out
Old Dec 20, 2006 | 05:58 PM
Turbo_TONY's Avatar
Go to the Forced Induction forum and you will get more answers.
But my OPINION is that a gsr..b16..or type r tranny wont keep the rpms in the LS's power band unless your reving over 7K. Vtec trannies are geared for high revving engines...the LS tranny is not...The LS motor (unless built) is not a high revving motor as we all know.
But just my .02
(P.S... sorry for the bad spelling...been at work all day)
Old Dec 20, 2006 | 06:00 PM
Default Re: LS-Turbo, should I switch to a VTEC tranny? (Turbo_TONY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_TONY &raquo;</TD></TR><TR><TD CLASS="quote">Go to the Forced Induction forum and you will get more answers.
But just my .02
(P.S... sorry for the bad spelling...been at work all day)</TD></TR></TABLE>
cool opinion...but track times say that your opinion is faulty ...Its not an OPINION that the b16 transmission significantly drops quarter mile times on an otherwise stock (Still going to 7k) LS
Old Dec 20, 2006 | 06:13 PM
Turbo_TONY's Avatar
Here is the LS-T thread in the FI forum. Im sure you can find some insight in there
https://honda-tech.com/zerothre...e=323
Old Dec 20, 2006 | 06:15 PM
DS002's Avatar
Banned
tighter gear ratios = faster , of course there are other factors to this
Old Dec 20, 2006 | 06:43 PM
95 integra's Avatar
Default Re: LS-Turbo, should I switch to a VTEC tranny? (DS002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DS002 &raquo;</TD></TR><TR><TD CLASS="quote">tighter gear ratios = faster , of course there are other factors to this </TD></TR></TABLE>
Until you get to the 400 ft/lb range and then tighter gears = more spinning.
Old Dec 20, 2006 | 06:56 PM
Default Re: LS-Turbo, should I switch to a VTEC tranny? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
Until you get to the 400 ft/lb range and then tighter gears = more spinning.</TD></TR></TABLE>
true...but if youre in a range where the spinning can be controlled with upping the rubber, then it will net the faster time
Old Dec 20, 2006 | 07:04 PM
DS002's Avatar
Banned
Exactly one of those other factors i was thinking off , fwd and 440 ft/lbs would make for some good smoke shows and thats about it
Old Dec 20, 2006 | 10:57 PM
onepuff's Avatar
keep the ls tranny
Old Dec 21, 2006 | 04:30 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (onepuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepuff &raquo;</TD></TR><TR><TD CLASS="quote">keep the ls tranny</TD></TR></TABLE>
no get the ITR tranny, LSD and shorter gears
Old Dec 21, 2006 | 04:51 AM
95 integra's Avatar
Default Re: (SupersonicBlueGSR)
BTW, for what its worth, with 250whp, I would get a GSR trans....or a B16/ITR w/ LS 5th gear.
Old Dec 21, 2006 | 09:03 AM
Kyoto now's Avatar
Default Re: (95 integra)
Yeah, the b16 trans I had in my last DA did a good job for daily driving around town, but that trip on the freeway to and from work everyday sucked. I just couldn't get used to reving that high and going so slow. But it was nice to actually have some pull in 5th. Does anyone know the top speed an LS would make with a B16 tranny on it? I raced my friends BMW 325Ci at El Mirage and it seemed to run out of room at 135mph. Is this correct? Thanks.
Old Dec 21, 2006 | 10:09 AM
95 integra's Avatar
Default Re: (DA9 Purist)
Roughly 130 and you'd be hitting the 7k mark.
Old Dec 21, 2006 | 10:56 AM
1337whp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">
no get the ITR tranny, LSD and shorter gears</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHTFP &raquo;</TD></TR><TR><TD CLASS="quote">shorter gears would make it faster
Old Dec 21, 2006 | 11:08 AM
Kyoto now's Avatar
Default Re: (1337whp)
is it hard to swap in the LS 5th gear?
Old Dec 21, 2006 | 02:03 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to swap in the LS 5th gear?</TD></TR></TABLE>
Not really, but you can f' things up rather quickly if you dont know what youre doing. Its not a beginner type task.
Old Dec 21, 2006 | 04:25 PM
vladd's Avatar
i'm voting for a b16 or itr tranny with an aftermarket lsd
SiR Inspired ED7
Apr 18, 2006 02:01 AM
judgeDredd
Nov 8, 2005 01:01 PM
blu3_hatch
Oct 31, 2004 01:50 PM
eathatch94
37
Jul 7, 2004 11:08 PM
michaelduvall
May 28, 2004 01:26 PM
