low idle...
Old May 12, 2002 | 05:55 PM
Balls's Avatar
Default low idle...
In the past month or so i've been noticing the idle drop a little low. Normally the idle at start is about 1.5k and gradually drops to 700-1100. That's still the case except after driving for a few miles and coming to a stop... the engine slows to about 400-500. Occasionally it will dip really low, almost to stall, but then it comes back to about 600... and it starts to slow again. When I tap the gas, it dips... then revs up. If I tap the gas really slow... or blip it real fast (like to downshift), there's no appearant problem.
I just had the dealer adjust the valves and it still seems to be a problem. I'm also coming up on an oil change.
Thanks!
Old May 12, 2002 | 05:57 PM
Pinhead's Avatar
New User
Default Re: low idle... (*****)
I have the same problem.....when the rpm drops my lights dim a bit also
Old May 12, 2002 | 10:02 PM
Balls's Avatar
Default Re: low idle... (Pinhead)
have you been able to address this issue in any way?
Anyone else?
Old May 12, 2002 | 10:17 PM
Honda F1's Avatar
Try adjusting the idle by turning the idle screw on the throttle body. Use a flat head screwdriver and turn it counter clockwise to raise the idle. Do it in small incriments. Also try resetting your ecu.
Old May 13, 2002 | 06:33 AM
Balls's Avatar
Default Re: low idle... (HONDAF1)
That seems like a good workaround for now... but what about the actual problem? I'll try the ecu as well. Thanks!
Old May 16, 2002 | 06:59 AM
Sleeper's Avatar
Reset the base idle speed. Warm up engine, unplug iac, use brass tb screw to adjust the base idle to around 500rpm. Turn off engine, plug iac back in, reset ecu. Messing with the screw without unplugging the iac will cause lots of headaches. If this doesnt fix it, troubleshoot the tps.
Old May 16, 2002 | 10:54 PM
Balls's Avatar
Default Re: low idle... (kennya70)
intereseting developement....
I was changing oil the other day when I realized that I pulled a fram filter off. I remember reading some crap about frams being poop just after i put i on. It sounded like a rumor or a handful of people who experienced bad luck... But oddly enough, the car's idle has somewhat returned to normal since I replaced it... It still dips when i tap the throttle but the idle seems steady...
Mind you, I only changed the oil yesterday so not a whole lot of data to go by, but I should mention that I drove in stop and go traffic today and didn't notice it at all.
Thanks for all the suggestions,
I'll keep an eye on this...
Old May 17, 2002 | 09:23 AM
spangler's Avatar
fram badd news buddies nissan 240 sx with sr20det swap it blew the filter right off and burned up his turbo
as far as low idel check you injectors honda injectors are junk
i had this problem in a prelude
changed injetors he never had a problem before
Old May 18, 2002 | 07:50 PM
Phil DeVtec's Avatar
Default Re: low idle... (spangler)
my idle is really low too...im gonna go ahead and try some of this stuff out tomorrow...where should i set it too? if it doesnt get fixed...could this mean HUGE problems for me or not really? thanks
Old May 23, 2002 | 08:59 PM
Balls's Avatar
Well... it's been a week and the car seems to be running better than it has in a while. The only thing I did was change oil and filter.
Kennya, sorry I couldn't be more helpful... unless you've got a Fram filter... oh.
99d-series
May 18, 2009 04:51 PM
fe519
Nov 21, 2002 05:58 PM
chirp2hrd
Oct 13, 2002 01:36 AM
