big bearing problem
well lads im fitting front and rear itr arms brakes etc etc on my ek.
the rear bearings are fucked. and i need to get this solved asap
can u change a bearing in the rear hub of an itr?? if so how
or do i have to change the whole hub??? thanks in advance lads
4lug, mmmm...i am sure you will have to press the bearing out and replace it with a new one. Not sure if this is same as usdm 5 lug. I am sure someone will have an answer, or you can go to a local shop.
thanks for the reply bud.
it would save alot of time and money if i was able to change just the bearing????but i dont no wether it can be done or not?
look for Willards post about Wheel Bearings, did a nice write up and pics a year or so about this. He shows how to do it and what parts/tools used to do it.
Big problem seems to be the part : Wheel bearing for 4 lug itr, do a search!?
good luck
good luck
I don't see the reasoning why Honda would make such a significant change in the 4-lug stuff as apposed to everything else they make.
Pressing wheel bearings in and out is definately a DIY project if you have a press and the right diamemeter dyes to do so.
PaChiLa Leader
Feb 18, 2009 05:21 PM
redman223
Apr 30, 2007 02:36 PM
