obd1 and obd2 injectors
Old Dec 20, 2006 | 12:38 PM
bmanuhutu's Avatar
Default obd1 and obd2 injectors
I have a 96 LS and its OBD2, however I want to get injectors for my turbo setup. I have seen obd2 and obd1 injectors. Is there any differences?
I am also going to get an OBd1 ecu, w/ a harness. but Im not sure which injectors I should get?
Old Dec 20, 2006 | 12:42 PM
lVlemphizStylez's Avatar
Default Re: obd1 and obd2 injectors (bmanuhutu)
the clips are different...Keep the obd2 injectors if you switch to obd1 ecu with jumper harness...because the engine harness hasnt changed, itll still be an obd2 plug
Old Dec 20, 2006 | 12:49 PM
tweekerz's Avatar
Default Re: obd1 and obd2 injectors (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">the clips are different...Keep the obd2 injectors if you switch to obd1 ecu with jumper harness...because the engine harness hasnt changed, itll still be an obd2 plug</TD></TR></TABLE>
Yup you need obd1 injector clips.
Hondatypr636
Aug 7, 2011 08:02 AM
SupaFly_Honda
Jan 12, 2005 02:05 AM
TsukubaSpec
Apr 24, 2004 08:20 AM
