Filter inside the IACV?
Old Dec 20, 2006 | 11:32 AM
Ritchie's Avatar
Default Filter inside the IACV?
i was wondering how important is the filter inside the IACV? as of right now, the iacv i have doesn't have the filter and i'm also having trouble installing it. anybody got any idea how to put it in or can i just leave it out?
Old Dec 20, 2006 | 12:06 PM
-HONDA-'s Avatar
the filter is a MUST i think! it plays the same role as your actual INTAKE,CAI, lets it breath smooth and keeps it from something getting stuck in there and chocking!
Old Dec 20, 2006 | 02:37 PM
Ritchie's Avatar
Default Re: Filter inside the IACV? (EGnewbie)
any idea of installing one because my iacv is missing the filter. i bought a new filter from honda dealership and having trouble putting it in.
Old Dec 20, 2006 | 02:59 PM
Amped's Avatar
why did you take it out? Are you haveing trouble because the filter is a little too big or what?
Old Dec 20, 2006 | 04:05 PM
Ritchie's Avatar
Default Re: Filter inside the IACV? (Amped)
i didn't take it out. i bought the iacv missing the filter. the filter is a circle and so is the hole, but for some reason it doesn't fit if you just push it in. the hole might be a little too small, but not quite sure.
Old Dec 20, 2006 | 04:13 PM
Amped's Avatar
can you take a rubber mallet and tap it in?
Old Dec 20, 2006 | 06:55 PM
hondamark35's Avatar
some of them don't have the filter... the main reason for it is to keep carbon build-up off of the internals. but if it gets clogged or the idle starts screwing up just clean it out with some carb cleaner or brake parts cleaner. that should work fine.
Old Dec 20, 2006 | 10:11 PM
Ritchie's Avatar
Default Re: Filter inside the IACV? (hondamark35)
oh okay that response make me feel okay to just go ahead and install the iacv. thanks.
Old Dec 20, 2006 | 10:53 PM
Yodastien's Avatar
im goona feel stupid for this but what is a IAVC
Old Dec 21, 2006 | 05:04 AM
EJ6_Hatch's Avatar
Default Re: Filter inside the IACV? (Yodastien)
Idle Air Control Valve
I just bought one to go with my Y8 IM swap
Old Jan 18, 2007 | 05:59 PM
HickamHatch's Avatar
Default Re: Filter inside the IACV? ({PBA}Threat)
Do you hook the vaccum port up to vacuum or leave it open?
hamadiscool
Nov 5, 2006 10:09 PM
red_ek_hatch
Mar 30, 2005 12:30 AM
GSRerrr
Nov 21, 2004 04:52 PM
