B16 Engine & Tach jump over bumps
Old Dec 20, 2006 | 11:26 AM
sohcguy's Avatar
Default B16 Engine & Tach jump over bumps
I had a B16 put in my car a year ago after my turbo D16 went out. The car has been running perfect until about 3weeks ago it started to stumble, the tach and engine would fluctuate wildly about + or -, a few hundred rpms. It finally died while I was driving down a bumpy road and wasn't getting spark, it ended up being the ignition coil. It still has the same problem though as if something is loose, before I put together that it was only stumbling when the car wasn't on perfectly smooth pavement, I changed the plugs, wires, cap rotor, fuel filter and some of the questionable vacuum lines. I reset the ecm, checked all the fuses, jiggled everything sensor I could think of to see if it was loose. Does anyone have any ideas on what I could check next?
Thanks
Old Dec 20, 2006 | 06:52 PM
sohcguy's Avatar
Someone suggested checking all the grounds, think I'll do that.
ttk3
16
Apr 23, 2007 11:21 AM
sohcguy
Dec 29, 2006 10:34 AM
tatted91rex
Feb 25, 2006 09:37 AM
sincityEX
Nov 7, 2004 07:38 PM
crxtreme27
May 5, 2003 07:15 AM
