I NEED HELP CRX WONT START!!!
Old Dec 20, 2006 | 09:51 AM
91ed9's Avatar
Default I NEED HELP CRX WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
my rex wont start, b16a in it btw.... i checked everythign no fuses are blown charged battery... this started last night.. i moved my battery in the back and it didnt start so i moved it back in the front and it started right up went to my friends house then went to get food... it didnt start then.. so i got a jump drove home... the next day (today) it wont start so i charged battery and nothgin... i checked everythign power going to starter, there is no voltage drop anywhere all grounds are fine ...tapped the stater a bunch and nothing... all it does is click
i need help asap!!! i dont have a car and i really dont want to change the starter i dont have anymoney!!! someone please help has this happeed to anyone>????????
Old Dec 24, 2006 | 01:54 PM
Mavrick's Avatar
Default Re: I NEED HELP CRX WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 (1991 CRX Si)
sounds like your main relay is bad. Have the car in neutral and have your friend try the key while you lightly tap on the starter. If it starts then you need a new one
Old Dec 24, 2006 | 01:55 PM
Mavrick's Avatar
Default Re: I NEED HELP CRX WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 (Mavrick)
could be a bad battery also, just because it shows 12 volts doesn't mean it has the proper cold cranking amps. Take it in and get it tested, that is the most likely problem. Or your battery cables are not tight.
Old Dec 24, 2006 | 01:56 PM
Tippyman's Avatar
Tap the starter? You mean directly wire it right?
Old Dec 24, 2006 | 02:03 PM
Mavrick's Avatar
Default Re: I NEED HELP CRX WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 (Tippyman)
could try that and do a remote start. I find to diagnose a bad starter when someone is trying the key a good tap on the starter can get it to start sometimes indicating the problem
Old Dec 24, 2006 | 04:07 PM
teler86's Avatar
try jumping the constant wire to the signal wire on the starter, while the key is in the on position then report back.
Old Dec 24, 2006 | 04:21 PM
J9D6M's Avatar
Default Re: I NEED HELP CRX WONT START!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 (teler86)
I just had the same problem with mine...Turned out that the pos wire terminal had just enough corrosion in it that I wasnt getting a good contact. A little bit of steel wool to clean it up and she purred like a kitten.
prowheelie92
Acura TL, RL & ZDX
Jul 11, 2012 06:26 PM
lawlss
15
Sep 14, 2009 10:23 PM
jorge59la
Sep 16, 2007 06:28 PM
Civic_Lover
Apr 2, 2007 01:59 PM
90EF8
Jul 14, 2002 09:45 AM
