revs good but no power please help.
Old Dec 20, 2006 | 09:04 AM
blackb16209's Avatar
Default revs good but no power please help.
i have a 2000 si that revs perfectly fine but as i took it for a drive, it lacks torque and wants to bog out. anyone faced a similar problem. the only piping it got is header and cat only, do i need the complete exhaust for back pressure. Also everytime i rev the motor would shake a little, seems like it is running on three cylinders, but its not. please help out a member, im a new honda owner, and have very little knowledge of hondas.
thanks viewing
Old Dec 20, 2006 | 09:06 AM
WhiteOnRice's Avatar
Default Re: revs good but no power please help. (blackb16209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackb16209 &raquo;</TD></TR><TR><TD CLASS="quote">the only piping it got is header and cat only, do i need the complete exhaust for back pressure. </TD></TR></TABLE>
Put exhaust back on and check.
Old Dec 20, 2006 | 09:11 AM
Default Re: revs good but no power please help. (fizix_skate)
also shows a check engine light flashihng. can that be the exhaust? all of my sensors are intack.
Old Dec 20, 2006 | 09:14 AM
^ lol (cause I did)
Old Dec 20, 2006 | 09:18 AM
GdmLaz's Avatar
if you have a b16 and are running without exhaust ur killin the poor motor THEY ARE TORQUELESS AND then you are taking the only lil torque they have
PLUS ALWAYS FIX PROBLEMS THAT ARE OBIOUS IF YOU HAVE A CHECK ENGINE LIGHT GET RID OF THAT FIRST
Old Dec 20, 2006 | 09:19 AM
instrument's Avatar
if you have your exhaust up to the cat then no, that wouldn't be the problem.
um, you should find what your check engine light is..... you may answer your own question.
Old Dec 20, 2006 | 10:05 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackb16209 &raquo;</TD></TR><TR><TD CLASS="quote">also shows a check engine light flashihng.</TD></TR></TABLE>
Outkast_CL9
Jan 9, 2006 12:01 AM
untitledsn41
Aug 30, 2004 04:01 PM
xkwzt21
Jun 9, 2004 07:38 AM
MaxBoost
Apr 8, 2003 10:22 AM
RacerXintegra2k
Jan 20, 2003 08:29 AM
