rustie fuel lines
yoi am helpin my boy out with is 92 acrua gs
he put a fuel tank in and ended up messin the main fuel lines up i went to honda and they said they don't make them any more
is there any way i can fix this????
thanks for the help
i don't thinki am gonna find a good fuel line the junk yard
thanks for the help
http://www.acuraparts247.com/p...ch=no
These are actual part numbers from an Acura dealer, take them to your local dealer and see if they have them, if not order from this dealer or Baranco Acura which is a sponser here.
Actually, by looking at the diagram, I don't know if all the lines are available or not. You might need to check your local junk yard or have custom piping done by a mechanic since special flare tools are needed. Or use rubber fuel line just to replace the short damaged section, but don't know if that would be good for a perm. fix or not.
marcj
Sep 28, 2010 10:40 AM
