Possible Tranny Problems
Old Dec 20, 2006 | 06:28 AM
OfFTheLiNe's Avatar
Default Possible Tranny Problems
Used B18 Auto tranny with 80,000 miles on it
so tonight we finally replaced myy tranny we got it all bolted upeverything is flush(motor to tranny) and plugs pluged in.
also replaced both axles
so we go to start it....
i put it into reverse and started to back out
than it started idleing really low like it wanted to die
while driving around i would floor it and it would have no pull at all
also when i push the gas it makes a banging nosie no idea what that is from
just really to hope to find a answer to what it may be
-thanks
Old Dec 20, 2006 | 06:57 AM
Boots's Avatar
Default Re: Possible Tranny Problems (OfFTheLiNe)
its because its an automatic
Old Dec 20, 2006 | 07:13 AM
OfFTheLiNe's Avatar
Default Re: Possible Tranny Problems (boots)
i know dont remind me man
5spd sway once i get the money for it
but need my car running right
Old Dec 20, 2006 | 08:25 AM
OfFTheLiNe's Avatar
i just cant figure out what is wrong
Old Dec 20, 2006 | 08:30 AM
dohc_profile's Avatar
Default Re: (OfFTheLiNe)
chek your spark plugs??
Old Dec 20, 2006 | 09:23 AM
OfFTheLiNe's Avatar
Spark Plugs are good
not to worried about it dieing as i am the clunk nosie
Modified by OfFTheLiNe at 12:14 PM 12/20/2006
Old Dec 20, 2006 | 11:32 AM
OfFTheLiNe's Avatar
sorry for bumping this but i
really needing to fix this problem soon
Old Dec 20, 2006 | 05:28 PM
OfFTheLiNe's Avatar
the plug or wahtever it is that goes there came out but the plug is still in there
not sure what its called
Old Dec 21, 2006 | 09:27 AM
OfFTheLiNe's Avatar
the specail clips that holds it in
where the plug should be in
Old Dec 21, 2006 | 10:26 AM
gsr dood's Avatar
looks like ur speed sensor
Old Dec 21, 2006 | 10:35 AM
OfFTheLiNe's Avatar
dont know if it is my vss or speed sensor gotta get it fixed tho
Old Dec 23, 2006 | 11:50 AM
OfFTheLiNe's Avatar
god i cant figure if it is my speedo cable or my vss
abercrombemonkey
Jun 11, 2006 08:37 AM
f150harleytruck7
Dec 2, 2005 07:31 AM
fe519
Jul 12, 2005 08:37 AM
brabbit
Oct 19, 2003 10:09 PM
