motor swap, car not starting with key
Old Dec 20, 2006 | 05:16 AM
stemiched's Avatar
Default motor swap, car not starting with key
Just did an sohc zc swap and the car starts, but will not start using the key.
Will be tracking down the issue tonight, where would you suggest to start my search to find the issue?
Old Dec 20, 2006 | 05:55 AM
civiconfire's Avatar
its not turning over, like not sending signel to the starter?
check to see if you pluged the starter in good (the little bolt and the wire that slips on).
Loserkidwac's Avatar
Default Re: motor swap, car not starting with key (stemiched)
how did you start it..jump the starter?? What happens when you turn the key, nothing?
Old Dec 20, 2006 | 05:58 AM
stemiched's Avatar
Default Re: motor swap, car not starting with key (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">how did you start it..jump the starter?? What happens when you turn the key, nothing?</TD></TR></TABLE>
im not sure what exactly is happening, my uncle has been working on the car, i know he has it started fine, but nothing happens when the key is turned. I assume he jumped the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiconfire &raquo;</TD></TR><TR><TD CLASS="quote">its not turning over, like not sending signel to the starter?
check to see if you pluged the starter in good (the little bolt and the wire that slips on).</TD></TR></TABLE>
it is turning over because the car has started.
Old Dec 20, 2006 | 06:45 AM
i ment as in the starter turning when you turn the key, not the motor starting.
i bet it has something to do with the starter signel wire. make sure its pluged in good or use a test light to see if it is getting power
Old Dec 20, 2006 | 06:53 AM
stemiched's Avatar
Default Re: (civiconfire)
alright, that will be the 1st thing i try tonight.
Timmyflys
28
Jun 25, 2007 03:11 PM
CrX-To-Tha-Max-v2.0
Mar 1, 2005 09:44 PM
oldschoolfreak
Jan 16, 2005 08:25 PM
SalmanzCivic
Jan 4, 2005 09:14 PM
ILOVEGIRLS
Sep 5, 2003 12:03 AM
