Moroso Pan, oil starvation during cornering?
Old Dec 20, 2006 | 04:07 AM
psycheus's Avatar
Default Moroso Pan, oil starvation during cornering?
Hey,
Wondering if anyone knows about these Moroso or OBX oil pans having problems for road racing or auto-x with oil starvation? Someone mentioned it to me but haven't been able to confirm or deny this issue. It was mentioned that the baffling system for the Moroso or OBX pans are only for front to back and from these pics it looks like that is the case. Has anyone welded another baffle into their pan to correct this? I'm working on my turbo project for road racing and Auto-x.
Here's both of the pans.
Thanks!
Rick
Old Dec 20, 2006 | 05:26 AM
SMSP's Avatar
Default Re: Moroso Pan, oil starvation during cornering? (psycheus)
Are those D series pans?
Old Dec 20, 2006 | 04:05 PM
psycheus's Avatar
Default Re: Moroso Pan, oil starvation during cornering? (SMSP)
Yes they are d-series pans.
Old Dec 20, 2006 | 04:19 PM
crvtecrob's Avatar
I thought they made different style pans depending on you driving needs?
Old Dec 20, 2006 | 07:01 PM
dr_latino999's Avatar
Default Re: Moroso Pan, oil starvation during cornering? (crvtecrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtecrob &raquo;</TD></TR><TR><TD CLASS="quote">I thought they made different style pans depending on you driving needs?</TD></TR></TABLE> Moroso in their 2007 Catalog only offers one style pan for the SOHC.
Old Dec 20, 2006 | 08:13 PM
0554's Avatar
yea. that looks nothing like my b series moroso pan. maybe they dont make different style d series. easiest way to find out is call them up
Old Dec 21, 2006 | 03:41 AM
psycheus's Avatar
Default Re: Moroso Pan, oil starvation during cornering? (0554)
I'm going to shoot an email but look what I found on their site.. That's the type of baffling system I really was looking for with this pan. I was also talking to a friend with a supercharged GTS Celica that has a Moroso pan and his looks like the one below.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "http://www.moroso.com/catalog/categorydisplay.asp?CatCode=11199" &raquo;</TD></TR><TR><TD CLASS="quote">Honda 1.3L & 1.5L, Road Race
Kicked-Out Sump
Aluminum
5.5 Quart Capacity
Fits: Honda 1.3L and 1.5L engines used in stock 1984-87 CRX models without chassis modifications
Fully fabricated all-aluminum construction offers exceptional strength without the added weight and provides several design advantages over stock-core pan
A cluster of four trap-door baffles completely surround the pickup to ensure ample oil supply and oil pressure regardless of hard acceleration, braking, or quick left/right cornering
Special oil control features are critical because the stock pan causes oil to move away from pickup during hard driving
Double kicked-out sump increases capacity to 5.5 quarts, while maintaining stock depth for ample ground clearance
Removable sump tray allows for easy cleaning, cools and de-aerates return oil, and keeps excess oil off of the rotating assembly to prevent horsepower-robbing windage
Includes one-half inch NPT bung at rear for fitting a temperature sender and one-half inch NPT bung at front for plumbing an oil return line for those running turbos (also includes two one-half inch NPT plugs if required)
Includes magnetic drain plug with extra copper washer
Also includes pan mounting kit with hex-drive steel studs to eliminate stripping the engine block and serrated-face flare nuts to withstand vibration
Accommodates stock pan gasket and dipstick with existing oil level marks
Use with stock oil pump and pickup
See Oiling System Equipment for External Oil Pump and Dry Sump Components.
NOTE: Oil Pan Capacities DO NOT Include Oil Filter Capacity.
No. Description/Application
20905 Aluminum, Kicked-Out Sump Pan, Honda 1.3L and 1.5L engines.
Old Dec 22, 2006 | 07:58 PM
Mr HYDE's Avatar
i run the new moroso road race pan and i like it
Old Dec 22, 2006 | 08:02 PM
Default Re: Moroso Pan, oil starvation during cornering? (Mr HYDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">i run the new moroso road race pan and i like it</TD></TR></TABLE> Yes, but is it for the SOHC?
Old Dec 23, 2006 | 06:55 AM
psycheus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Mr HYDE" &raquo;</TD></TR><TR><TD CLASS="quote">i run the new moroso road race pan and i like it </TD></TR></TABLE>
What engine do you have? What is the part number for that pan? What do you use you car for (ie. HPDE events/auto-x/or just street use)?
Jdmsoles
Nov 9, 2008 04:05 AM
cmqqn85
Welding / Fabrication
Dec 12, 2007 03:33 AM
ekim952522000
Dec 15, 2005 08:35 PM
Dragger817
Apr 24, 2003 10:41 PM
MARC P
Apr 14, 2003 06:53 AM
