DOHC ZC with a Z6 Trans
My friend has OBD-0 ZC sitting in his garage from his now B16 CRX. I recently blew my Z6 and I was wondering what was all needed to do with this swap. I have read about removing the halfshaft and what not from the ZC.
Im just trying to get my Del Sol running. Also does anyone know where I can find a OBD-1 ZC dizzy? Also how different are the two exhaust manifolds???
edit:
Also what parts would I be able to change over from my Z6 to the DOHC ZC? Is it possible to convert the ZC dizzy to OBD1?
Modified by Gold DA9 at 7:08 AM 12/20/2006
edit:
just start bolting up obd1 and up distributors and find which one will workj the best. You might only get one or two bolts to match up. Then i guess you could make an adapter plate out of sheet metal.
trans will bolt up to the engine fine, remove the zc halfshaft and use your stock z6 axles.
worst comes to worse and you have a 1988 zc. If that's the case, use your z6 clutch/flywheel/pressure plate
low91rex
12
Aug 6, 2007 10:27 AM
