Don't have a problem Over heating but UNDER heating
Old Dec 20, 2006 | 12:51 AM
Mikizzle's Avatar
Default Don't have a problem Over heating but UNDER heating
I will drive around for about 1.5 hours and the temp needle is directly under Cold. The hottest it ever got in the last 2 month was about 1/8.
I tried to search but everything was about over-heating.
Are there any other key words to search for?
Old Dec 20, 2006 | 12:58 AM
Micha's Avatar
FAILWGN
Default Re: Don't have a problem Over heating but UNDER heating (GrnTurtle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrnTurtle &raquo;</TD></TR><TR><TD CLASS="quote">I will drive around for about 1.5 hours and the temp needle is directly under Cold. The hottest it ever got in the last 2 month was about 1/8.
When is the last time your thermostat was changed? Could be stuck open, causing the coolant to continuously flow and not allowing it to warm up.
Old Dec 20, 2006 | 05:18 AM
Azn Kenny's Avatar
I had the same problem in my LS, replaced the t-stat and everything was back to normal operating temps.
Old Dec 20, 2006 | 05:51 AM
Swiftstar's Avatar
hey. thats exactly whats happening to my RS now.. hmmm. so .. just go to the nearest Honda dealer and ask them to change the T stat? is it Costly?
Old Dec 20, 2006 | 06:01 AM
tweekerz's Avatar
Exact same problem with me. If I left the car in idle long enough the car heated up but would drop down as soon as I started driving.
Your thermo is stuck open, make sure to buy a new thermo and the gasket. Cheap and easy, there is a team-integra.net article on a DIY. Here is the link.
http://www.team-integra.net/se...D=222
Old Dec 20, 2006 | 06:44 AM
AllMotorDan's Avatar
Yes Get your Thermostat changed and you'll be fine
Old Dec 24, 2006 | 12:27 PM
Mikizzle's Avatar
thanks alot, for a second i thought it might have been a big problem.
Anyone know the part number for stock? thermostat and gasket?
Or are there better aftermarket ones to replace it with
Old Dec 29, 2006 | 04:25 AM
Mikizzle's Avatar
anyone?
Old Dec 29, 2006 | 05:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I just went to a Honda dealer and ordered a 99-00 Si thermostat, since they were alot closer than the Acura dealer.
Old Dec 29, 2006 | 06:53 AM
jdm_bones's Avatar
Default Re: (GrnTurtle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrnTurtle &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot, for a second i thought it might have been a big problem.
Or are there better aftermarket ones to replace it with</TD></TR></TABLE>
mugen makes a nice aftermarket thermostat, but it cost a pretty penny...just get the OEM you'll be fine! Mugen is just bling!
Old Dec 29, 2006 | 06:56 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (jdm_bones)
Go OEM... Autozone ones suck.. Only good aftermarket ones are really $$$
93ludesitec
Jun 27, 2006 06:05 PM
Downs
Dec 7, 2005 03:37 PM
rdaggett
Aug 11, 2004 12:48 PM
19da90
May 18, 2004 02:11 AM
cjames235
Dec 12, 2003 07:43 PM
