b16b pistons in b16a2?>>
hello...the b16b pistons (dumn i dont know their code) if they will be put in a b16a2 block with STOCK b16a2 head....what cp will it have?
do we have any clearance problems , valves hittin the piston??
and sth else, what rods do i need?? my stock b16a2 ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teri_vti »</TD></TR><TR><TD CLASS="quote">hello...the b16b pistons (dumn i dont know their code) if they will be put in a b16a2 block with STOCK b16a2 head....what cp will it have?
and sth else, what rods do i need?? my stock b16a2 ??</TD></TR></TABLE>
B16B is a CTR (PCT) piston. You will need to shave 1mm from each side of the small end of the rod, where the wrist pin goes.
Compression would be......
PR3 head/B16 Block
STD = 11.643438609136867
.25 OS = 11.703231023151065
https://honda-tech.com/zerothread?id=717928
And no to the clearance problem question.
PR3 head/B16 Block
baulum
33
Dec 21, 2007 10:03 PM
CrazyKoreanCrx
Feb 26, 2004 01:45 PM
