91 HB swap to B16A
I was reading an article on this month Honda Tunning and they were talking about an EG w/ a B series swap. They had mention the fact that you can have AC if you get the B series bracket. What I want to know is if i can keep my AC by doing the same thing w/ my EF considering the different body styles and engine bays. Will the brackets fit and if so what kind of modefication will I have to make?
you can retain your A/C with a swap after all real SiR's had AC, you just need the bracket on the block.... its hard to get a swap that still has them on there because most people find it unnessessary ya know...
Now for my next question. Can I us my D16A tranny on a B16A motor, to save some cash? I know a cable trnny is better but cash is an issue so can I us the tranny for the mean time at least?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endo617 »</TD></TR><TR><TD CLASS="quote">Now for my next question. Can I us my D16A tranny on a B16A motor, to save some cash? I know a cable trnny is better but cash is an issue so can I us the tranny for the mean time at least?</TD></TR></TABLE>
Nope can't use a D to a B.
try hitting the F.A.Q. or the big red search button both of these question could have been dealt with.
Use a P54 ac bracket or the the Hasport EFBAC bracket...(what I'm doing...)
Check it out here.....
http://hasport.com/shop/produc...id=84
Or ....P54 Del Sol front driver’s side mount bracket (Honda P/N 38930-P54-000)
for any more questions you EVER have first look through the search. Im not trying to sound like a dick but the answer to your question was just a few clicks away. It would have taken about 3 minutes.
also not to sound like a dick but you shouldnt be doing this swap if you are asking that question.. you obviously need to do some more research.
i gotta another question, i wanna change my rear drum brake and all i wanna know is how much it would cost me(ball park figure), if any has had it done or knows anyone
this are the parts i was told to get and tools needed:
Salvaged Acura disc-brake assemblies
Slotted rotors
Replacement brake pads
Brake master-cylinder
Brake power-booster
Brakes distribution block
Degreaser
Brake cleaner
Braided steel flex-lines
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
Jack stands; wheel chocks
Slotted rotors
Brake power-booster
Degreaser
Brake cleaner
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endo617 »</TD></TR><TR><TD CLASS="quote">this are the parts i was told to get and tools needed:
Slotted rotors
Brake power-booster
Degreaser
Brake cleaner
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
Jack stands; wheel chocks</TD></TR></TABLE>
for all ^this^ at least $1000, or way more depending on what tools you need to buy.
here's all you really NEED to do it:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endo617 »</TD></TR><TR><TD CLASS="quote">Salvaged Acura disc-brake assemblies
Brakes distribution block (aka "proportioning valve" - i'd recommend it)
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Floor jack
Slotted rotors
Brake power-booster
Degreaser
Brake cleaner
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Floor jack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endo617 »</TD></TR><TR><TD CLASS="quote">i gotta another question, i wanna change my rear drum brake and all i wanna know is how much it would cost me(ball park figure), if any has had it done or knows anyone
Slotted rotors
Brake power-booster
Degreaser
Brake cleaner
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
i hope this guy is joking
Slotted rotors
Brake power-booster
Degreaser
Brake cleaner
Sandpaper
Wire brush
Masking tape
Wire hanger
Caliper paint
Drop cloth
Brake fluid
Small bucket
Clear hose
Clear bottle
Line wrenches
Pneumatic tools
Floor jack
yeah i know that the article is about changing the drums to rotors and upgrading the brake system itself at the same time, but i get wat ur trying to say i'm not getting all that stuff, i'm a low budget honda owner.
I just got a rear disc swap for a H-T member sold it for $250..it included:
Rear trailing arms
Calipers
Used rotors and Pads
E-brake cables
Prop valve
Brake booster
Master Cylinder
That should be all you need to do the swap, grab a flare nut wrench for the brake lines and then some new pads, rotors and fluids
Rear trailing arms
Calipers
E-brake cables
Prop valve
Brake booster
Master Cylinder
