H22A Swap Idling ruff
Old Dec 19, 2006 | 10:04 PM
duceducecord's Avatar
Default H22A Swap Idling ruff
i have a 96 honda accord lx with a 93 jdm h22a and it seems to be jumping up and down between 1000rpm and 400 rmp the idle is really rough. sometimes when i gas it and let it go it revs by it self n it really gets annoying. ive checked for vacum leaks everything seems fine. i dont know which sensor to check and also when i warm up my car sometimes the idle jumps up and down from 400rpm to like 3000rpm for a lil bit then it goes back to the idling rpm with a steady idle. i dont know what else to check for!!!!!
Old Dec 20, 2006 | 10:40 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Check the 2 valves that are on the throttle body. One is the IAVC and the other is below. I had a problem and it was the other one (Idont know the name) anyway theres a screw in there and it was loose, so we tightened it and my idle went back to normal
Old Dec 20, 2006 | 11:06 PM
mtnwkr's Avatar
Default Re: (mozzandherb)
http://www.ef-honda.com/ben/Badidle.php
Old Dec 21, 2006 | 04:14 PM
Default Re: (mtnwkr)
hell yeah koo koo it works thanks alot
Old Dec 21, 2006 | 08:35 PM
it was my idle booster or watever u kall it but yeah i pluged it up before to stop this poping noise but i guess it was the one that messed with my idle so i took out the plug thanks for the help tho
mikelesnick
Aug 7, 2018 02:05 PM
duceducecord
Dec 21, 2006 08:34 PM
duceducecord
Sep 3, 2006 05:58 PM
GOTNOS
Nov 28, 2004 04:05 PM
accord-lude
Nov 15, 2004 11:01 PM
