thermo valve issue..gsr
Old Dec 19, 2006 | 09:24 PM
conceptEG's Avatar
Default thermo valve issue..gsr
hey guys my thermo valve is going out. reving to 3k then to 500 and so forth..its driving me nutts.. i plugged the lower hole in the t/b and it stopped.. so i went and got a new t/b gasket and im going to pull it apart..
ive searched.. can anyone walk me through the process of tearing this thing apart and how to fix it.. understood i have to remove the t/b and it sits just under it..so i know what im looking at..
ideas or info would be highly appreciated!!!
thanks
brian
Old Dec 20, 2006 | 02:20 PM
RyanA's Avatar
Default Re: thermo valve issue..gsr (conceptEG)
It's the part that the coolant lines hook to when you pull the TB off. Take the 2 8 mm screws out of the cover part of it. Screw the nylon "donut" back in using 2 straight screwdrivers. Screw it in as tight as you can get it. Put it all back together and fill your coolant.
Old Dec 20, 2006 | 05:38 PM
JimBlake's Avatar
What year is the GSR engine? At one point (maybe '96?) they eliminated the FITV & included that function in the newer IACV.
Old Dec 20, 2006 | 07:03 PM
so lazy's Avatar
jimblake is correct... would help on the year of the motor.... but if it does have the fast idle the follow what ryana said..
Old Dec 25, 2006 | 06:43 AM
conceptEG's Avatar
Default Re: thermo valve issue..gsr (dc2-guy)
its a 95..in a 94 civic si but i know that doesnt matter..yea i cant stand having the throttle go up and down and up and down...its killing me
Old Dec 25, 2006 | 09:27 AM
JimBlake's Avatar
The '95 DOES have a fast-idle thermo valve. It's #13 in the picture, on the bottom of the throttlebody.
You can also check & clean the idle-air control valve on the manifold, #14.
Make sure you bleed ALL air out of your cooling system, either one of these valves can get confused when air comes thru their coolant hoses.
crazybeanery0
Nov 18, 2013 01:11 PM
n0rmaL
Dec 1, 2006 04:40 PM
Ef-9 Refresh
Oct 3, 2006 09:53 AM
89 civic si
Sep 26, 2006 08:17 AM
dvcart106
Aug 5, 2003 10:44 PM
