Fawk me... Mazda Rims do not clear Spoon calipers.. now what?
Old May 12, 2002 | 04:41 PM
AssPenny's Avatar
Default Fawk me... Mazda Rims do not clear Spoon calipers.. now what?
I am just having a kick *** weekend. Spend $160 bux at sears getting 2 sets of mazda rims mounted with Azenis and S03's so I could swap out my bent ITR rim from my lovely acciedent (https://honda-tech.com/zerothread?id=183269) So I go to put the rim on and low and behold, the pos does not clear the rim. So now I've got to figure out what to do. Do I run a spacer or machine the calipers. What do you all think. If I run spacers do I run them on the front and rear? Also who has spacers? I'll probably pick up 3mm (if they got them) and 5mm and figure out which one fits. Thanks for all the help guys.
Craig - Who is having a really shitty weekend
[Modified by AssPenny, 8:48 PM 5/12/2002]
Old May 12, 2002 | 05:26 PM
D's Avatar
D
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (AssPenny)
how close is it?
hell, i'd take a die grinder to spoon calipers....
D
Old May 12, 2002 | 05:32 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (D)
Should we bring down beer for next week's fix it weekend?
Marc ---> who wants Craig's car to be fixed
Old May 12, 2002 | 06:45 PM
AssPenny's Avatar
how close is it?
D
I was thinking of pulling them off and throwing them on the milling machine But it looks like its a good 5mm
I'll take a closer look at it tomorrow. I was just pissed and had been working on the car most of the day. Also sweating like a fat kid was not helping.
Craig - Who says ******* the spoon logo, thats 3mm's right there
Old May 12, 2002 | 06:54 PM
D's Avatar
D
all in the name of weight reduction....
Old May 12, 2002 | 06:56 PM
Willard's Avatar
Sell them biches to me... cheap!
Willis
-who would have gone crazy if he had Craigs' weekend...
Old May 12, 2002 | 07:58 PM
AssPenny's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (Willard)
Willis
LOL, sure.. but since they are special black editions, thats going to cost a bit more
And will, this is only part of my lovely weekend
Craig - Who had a rough weekend, even with out the wreck
Old May 12, 2002 | 08:24 PM
Black R's Avatar
25 Year Member
.....i was gonna suggest a 5mm spacer and go from there.
Please sell me the calipers if you're really gonna machine them!
I've got a black slipstream you can run in the meantime as a spare if you want.....
Old May 12, 2002 | 08:33 PM
garagespecial
Guest
Posts: n/a
i was told that you need n 8 mm spacer to clear the spoon caliper with 15 in spoon wheels
Old May 13, 2002 | 06:46 AM
AssPenny's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (garagespecial)
Anybody know where i can order spacers asap? SwiftTypeR, that link did not work.
Craig -
Old May 13, 2002 | 06:53 AM
ARunto's Avatar
Options carries spacers:
http://www.optauto.com/webstore/prod...t=407&last=407
-Alan
Old May 13, 2002 | 06:56 AM
AssPenny's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (ARunto)
Do I need longer studs when running a 5mm spacer?
Old May 13, 2002 | 07:00 AM
Cosworth's Avatar
Most likely.
Old May 13, 2002 | 07:03 AM
AssPenny's Avatar
Smallest spacer they have is 5mm, anybody know where to find a 3mm spacer?
Old May 13, 2002 | 07:43 AM
TodaCivic's Avatar
Craig, that sucks....you just have some bad luck.
I say just get some spoon wheels.... screw it!..
Good luck with finding the spacers tho.
See ya at the sept meet.
LATER
Old May 13, 2002 | 08:52 AM
AssPenny's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (TodaCivic)
To bad I just spend 160 bux on getting 2 sets of tires mounted on these rims
So does anybody know where to get 3mm spacers?
Craig - Who says to all HT'ers (looks like I might be able to get this fixed before expo )
Old May 13, 2002 | 08:56 AM
austrian type-R's Avatar
Buy the 5mm spacers and machine them down to 3mm
Old May 13, 2002 | 08:58 AM
ben_vtec's Avatar
New User
they rekon if you get 6.5 turns you dont need longer studs.
i dont know exactly who 'they' are
Old May 13, 2002 | 10:13 AM
rolow's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (austrian type-R)
Here in AZ you can get spacers from Pepboys & Checker.
Do you guys have Pepboys in Florida?
There not the best but they get the job done
[Modified by rolow, 7:13 PM 5/13/2002]
Old May 13, 2002 | 10:18 AM
AssPenny's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (rolow)
Yeah we have pepboys.. I'll have to check that out if my other solution does not work. The calipers are spaced about 5mm right now off the hub assembly with washer to center the calipers around the rotors. I'm going to try to remove the washer or run smaller washer and see if that will allow them the clear the rims.
Craig - Who hopes this works else he is just going to get some +40 offset rims like he saw on that 64 impalla
Old May 13, 2002 | 10:23 AM
reefer_bob's Avatar
16 x 7 Rota C-8's are +40 offset... Cheap, $125 each!!! Your choice of colors!!
Old May 13, 2002 | 10:37 AM
Black R's Avatar
25 Year Member
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (reefer_bob)
.....those are 4 lug!
Craig, try h&r for GOOD high $ spacers. They *might* make 3mm, but I know they make 5mm... Then take them to pep boys and put it on the lathe for a couple bucks.
Old May 13, 2002 | 10:39 AM
reefer_bob's Avatar
Default Re: Fawk me... Mazda Rims do not clear Spoon calipers.. now what? (Black R)
Ok then, Rota Sub-Zeros, 16 x 7 , +40, 5 x 114, $125 each...
Old May 13, 2002 | 10:41 AM
AssPenny's Avatar
I'm going to see if I can get away with moving the caliper in by removing thouse washers. If not, I've got a metal lathe down in miami i can use to machine down to 3mm
Old May 13, 2002 | 10:44 AM
cobalt's Avatar
New User
Get a 7mm hubcentric spacer with longer studs...
-andie
