alright
Old Dec 19, 2006 | 09:06 PM
IP RACING's Avatar
Default alright
after long hesitation.... I came to the conclusion of getting a swap instead of scrapping my ef sedan...... I saw a member of ef sedan quad rolling down the road... and It made me want ot be a part of it... I love that little 4dr.... I have $1,000... what site would you recomment o get a complete swap from... Im either looking into a dohc zc or a good d16a6... I wont have to switch to mpfi considering it already is mpfi... alright so basically I need to know if I get the dohc zc... what else do I need besides a new ecu... I know motor mounts are the same.... wiring is basically identical... so just ecu... how much am I looking at fully done.... Ive seen sites where the engine and tranny etc are like $550 plus shipping.... is there anything I am missing... I believe its just plug and play... what ecu should I run... respond asap please need this motor In quick my dd is dead
Old Dec 19, 2006 | 09:14 PM
Under Con. CrX's Avatar
Default Re: alright (IP RACING)
it is a plug and play but i belive you are going to need a PM7 Ecu wich will run you about 125-175 but 550 for the motor and trans is good make sure you have enough money saved away for insurance abuddie of mine beaught a DOHC ZC and when we started it his timeing belt snaped so beready for that and i think thats it
(some correct me if i am wrong about the ecu)
Old Dec 19, 2006 | 09:33 PM
C_R_X_V_T_E_C's Avatar
Default Re: alright (Under Con. CrX)
if you can get a DOHC ZC for 550 get that ****! Plus like 150 for the PM7 FAWK Yea, you should always save sum extra Muula Just in case cuz ya never know what could happen when you go to swap an engine.
Old Dec 19, 2006 | 09:42 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote"> when we started it his timeing belt snaped so beready for that and i think thats it
This is a maintenance item, would you use the oil that came in the motor too? replace timing belt/WP/tensioner. valve cover gaskets, plugs, wires, cap, rotor, clutch,throw out bearing, flywheel, exhaust manifold gasket, fuel filter, air filter, pcv valve, oil filter+oil,trans oil,axles, if you dont replace before the motor goes in you will be kicking yourself later when it will be much harder to change this stuff will run at least $300-$400 easy. so make a strict budget and plan everything out, make sure you have all the parts ready before the motor comes
I think you can chip your ecu with a pm7 program, its much cheaper than buying the ecu. like $75 to chip your stock pm6 with the pm7 program
Old Dec 19, 2006 | 09:57 PM
IP RACING's Avatar
Default Re: alright (Crx Jimmy)
alright well I think Im gonna get my swap from hmotorsonline.... ... seems pretty legit... what do you guys think though sohc zc or dohc zc.... is the extra $150 worth the extra like 9 hp... Im not looking for a lot of gain just reliability.. Im just gonna be putting on a cold air intake, headers iriduim plugs and wires.... basic bolt ons.. so Im just looking for like 150hp Id settle for like 140 even.. juust need to get my car up and running again... anyone... have an idea how much shipping would be to so cal..... doesnt say\... and yea Ill be having like $400 as insurance money... hopefuly it will just go in like nothing though.. I need some lowering springs.... and strut bars
Old Dec 19, 2006 | 10:08 PM
personaly i would go with single i have know a bunch of people who have had one its one damn reliable motor
and about shiping i dont know i pretty some one around here dose though good luck be sure to post pics of your swap when you get your stuff in
Old Dec 19, 2006 | 10:10 PM
IP RACING's Avatar
thanx people Id still like some more info on shipping and stuff Im going to call tomorrow... and yes once I get the motor Ill be taking lots of pics.. so be sure to watch out for it
Old Dec 19, 2006 | 10:13 PM
when you start send me a message i would love to follow your swap
Old Dec 20, 2006 | 10:29 PM
IP RACING's Avatar
what ecu goes with the sohc zc.. or whats best for it
Old Dec 20, 2006 | 10:39 PM
IF YOUR GOING WITH THE SINGLE I BELIVE YOU CAN GO WITH A PM6 CUS ITS MPFI
Old Dec 28, 2006 | 12:24 PM
IP RACING's Avatar
So I went to h motors to go get the engine and tranny.. it looked pretty cleaned everything seemed as good as new.. so were putting it in the jeep and **** and hes like well your gonna need the axles for e zc tranny.. I was like what.... hes like yea you need different axles... I Didnt know it had an intermediate axle and it needed da axles... so zc 5 speed tranny. sohc zc. and da axles .. all in all total was $750....... he said the engine had 40,*** miles...
Old Dec 28, 2006 | 01:53 PM
IP RACING's Avatar
hey well my dad went o his mechanic and asked how much it would be to put in...they want $750 with full install and for sure start up.... they said they have to do smog ****... i dont get it... its a sohc zc... what do you need to do
Old Dec 29, 2006 | 02:16 PM
IP RACING's Avatar
progress... Ill have pics up soon... Im taking out as much as I can I have radiator off. the full intake off.. most of the hoses and wires inplugged if possible Im gonna drop the motor tomorrow....
Old Jan 5, 2007 | 11:01 PM
so how did it go you never posted pics up your last post was on the 29 thats about a week now so are you done hos is it going any problems??
Old Jan 7, 2007 | 08:07 AM
IP RACING's Avatar
well The old motor is out of the car....and the new one is almost ready to drop in... I just need to remove the old flywheel I need to use that again dont have enough money for a lightweight.... and Im also waiting on intermediate shaft bolts Im going to honda tomorrow..... Ill post some pics when I get back from work....
Old Jan 9, 2007 | 11:14 AM
thats good keep up the good work
i need pics lol jk take your time
Old Jan 9, 2007 | 11:29 AM
ExemptedNut's Avatar
in for pics also I'm leaning towards getting a dohc zc...or hell a sohc zc...I dunno, I need an engine lol thats all I know.
I wil be checking back for updates!
Old Jan 9, 2007 | 01:00 PM
IP RACING's Avatar
Default Re: (ExemptedNut)
I made a build thread check it out!
https://honda-tech.com/zerothread/1858489
turbob18si
Apr 9, 2008 07:02 AM
dirttrackracer
Feb 5, 2008 09:39 AM
CTL
Jun 19, 2004 12:39 AM
