ATTN: All Motor Guru's......I need your help =)
Old Dec 19, 2006 | 08:56 PM
Synergy001's Avatar
Default ATTN: All Motor Guru's......I need your help =)
I did a search but none of the topics were related to what I am asking. I just bought a 94 B18C1 and was just going to replace the gaskets and timing belt/water pump before putting into my car. But when i thought about it and decided that I wanted to build it up since the motor is out. Anywho my goal is to hit around 180-200whp. Since I have no experience in building an NA motor I need your help. Oh and the car will need to be reliable and on pump gas since it will be DD.
The parts that I have bought so far is the blox IM, pro products 68mm TB and re-chipped p28 (I may have to get a different chip now). I plan to use P30 pistons to bump up my compression (not sure if I should go STD or OS). I also plan on changing all my bearings and rod & head bolts. As for the head, what valvetrain should I go with (I was thinking omniman but not sure if it will help me reach my goal). As for the cams I was thinking about using the blox type b's. as for the header i found a brand new jdm vibrant 4-1 header for $200 from a local (i know that header isnt that great but it's something that i can afford for the time being). Let me know what you guys think. TIA!!
Old Dec 19, 2006 | 09:09 PM
LSVTEC 91 Civic's Avatar
Banned
Sounds like you already have a nice setup in mind
Old Dec 19, 2006 | 09:13 PM
all-mtr-teg's Avatar
Default Re: ATTN: All Motor Guru's......I need your help =) (Synergy001)
i got a set of brand new type b cams for sale if you're interested. But yeah, good start. Maybe look into b16 tranny if you're not driving too much.
Old Dec 19, 2006 | 09:14 PM
Default Re: ATTN: All Motor Guru's......I need your help =) (all-mtr-teg)
By the way, synergy, are you from central cali? I grew up hearing about a crew in (661) called Synergy
Old Dec 19, 2006 | 09:38 PM
Synergy001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">By the way, synergy, are you from central cali? I grew up hearing about a crew in (661) called Synergy </TD></TR></TABLE>
yeah i used to be from central cali. thats where the crew started out back in '93 with just a group of close friends. i branched it out in hawaii and texas. hopefully oregon soon, i just need to get my car back up to par. i used to be a d series guy but decided to try out the b series.
Old Dec 19, 2006 | 09:40 PM
Synergy001's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you already have a nice setup in mind </TD></TR></TABLE>
cool so if i follow through with the parts i stated i should be doing pretty good w/o P&P'ing the head? what numbers do you think i might get. of course tuning plays a big factor. i just want a rough estimate of where i may be.
Old Dec 19, 2006 | 09:45 PM
Banned
Default Re: (Synergy001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synergy001 &raquo;</TD></TR><TR><TD CLASS="quote">cool so if i follow through with the parts i stated i should be doing pretty good w/o P&P'ing the head? what numbers do you think i might get. of course tuning plays a big factor. i just want a rough estimate of where i may be. </TD></TR></TABLE>
Hard to say how much power you put down, there are too many variables. You'll have to take it to a dyno and find out. You can get more power via headwork, just take the head to a reputable machine shop that knows what they're doing.
vtec4deaththo
21
Jun 5, 2009 07:10 PM
hybrids2k
Jan 26, 2009 12:38 PM
TypeGSR196
Mar 24, 2005 08:41 AM
enkeirp02
Feb 12, 2004 10:16 AM
eg crunkmonster
Mar 6, 2003 08:26 AM
