ls/vtec
Old Dec 19, 2006 | 08:17 PM
dkrex001's Avatar
Default ls/vtec
what head would you recommend for a ls/vtec.
i am N/A right now but in a year or so i will be going turboed.
and would you recommend gitting it tuned if just ls/vtec N/A
Old Dec 20, 2006 | 01:01 AM
Redline130's Avatar
Default Re: ls/vtec (dkrex001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">what head would you recommend for a ls/vtec.
and would you recommend gitting it tuned if just ls/vtec N/A</TD></TR></TABLE>
A PR3 (B16A) head would probably be the cheapest to pickup. It really wouldn't hurt to get it tuned while it's still N/A, however, if you are on a budget, then save your money for when you are turbocharged.
Old Dec 20, 2006 | 05:52 AM
E_F_9's Avatar
And this is in the EF section because..
Old Dec 20, 2006 | 05:56 AM
crxnj's Avatar
Default Re: ls/vtec (Redline130)
i like the gsr's intake manifold but just get a b16 head ,like you know they're everywhere and usually not expensive.
a stock pr3 ecu would run the motor decent,,alittle lean cause of the 1.8 litre but nothing to cry..then when you go turbo you can use BRE with the pr3
Old Dec 20, 2006 | 09:10 AM
dkrex001's Avatar
Default Re: ls/vtec (mr.speaker)
is the pr3 obd1
because my car is converted with a jumper and harness by rywire to obd1
Old Dec 20, 2006 | 09:25 AM
xDicktonesx's Avatar
actually, all vtec heads are hard to find right now.
there are only 2 choices. and really there is only one choice, which is any vtec head you can find complete for under 500 bucks.
Old Dec 20, 2006 | 09:40 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">is the pr3 obd1
because my car is converted with a jumper and harness by rywire to obd1</TD></TR></TABLE>
there are obd1 pr3's, but they're pretty uncommon...What ecu do you have now, the obd1 pr4 ls? if you get the gsr head you can get the p72 and have it runnin damn near perfect except for throwing a code for the knock sensor... maybe just have the ecu you have now chipped with crome ,,so this way when you go turbo you already have a socketed ecu atleast.
Old Dec 20, 2006 | 09:43 AM
dkrex001's Avatar
i have a p28
Old Dec 20, 2006 | 10:09 AM
crxnj's Avatar
Perfect. you converted to obd1 and have a p28 ,you know what's going on..have it chipped with crome ,,any tuners/chippers in your area?
Old Dec 20, 2006 | 10:11 AM
dkrex001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Perfect. you converted to obd1 and have a p28 ,you know what's going on..have it chipped with crome ,,any tuners/chippers in your area?</TD></TR></TABLE>
i am obd1 converted by rywire
tuners no but there is some about 2 to 3 hours away
i live in indiana and it is in ohio
Old Dec 20, 2006 | 10:27 AM
crxnj's Avatar
check these out http://www.ssc-das.com/ http://www.indyimport.com/ both are in indiana
edit 2nd website is down but the address is
Indy Import Performance--5813 W 73rd St--Indianapolis,IN
Old Dec 21, 2006 | 06:19 PM
dkrex001's Avatar
thanks but indy is 2 hours away
i am in fort wayne indiana
Old Dec 22, 2006 | 07:52 PM
jakscivic's Avatar
Most vtec heads are about the same. ITR is slightly more ported and all that buisness but its not really worth the extra 300 or so dollars you would need to spend to get it.
You said you converted to obd1? So if you used the rywire harness then that means you have obd0 plugs in your engine bay. So your best bet is to get a pr3 obd0 head. Although obd0-1-2 heads arent a whole lot different. The intake manifold is a little different but most of the plugs are the same. For less of a headache go for obd0 pr3. More common and pretty much the same as all the rest of the vtec heads.
Old Dec 22, 2006 | 09:52 PM
dkrex001's Avatar
Default Re: (jakscivic)
so you are saying to go back to obd0
that is dumb tuning is **** for obd0
i plan on going turboed in about a year
i will just use the p28 and git it tuned
Old Dec 22, 2006 | 10:38 PM
jakscivic's Avatar
no, im saying you just have the obd1 conversion harness that goes inbetween the obd0 ecu plug in and the ecu. The harness just makes you be able to use the obd1 ecu. But you still have the stock obd0 plugs in your engine bay. Which means it would be easier for you to stay with obd0 stuff because those are the plugs you have.
Old Dec 23, 2006 | 03:14 PM
leach's Avatar
Default Re: (dkrex001)
i would use the p28 use hondata s100 which comes with the boost option for the same price as without as far as heads go good luck i bought a hole b16 for 500 and used just the head .good deals come around when you dont need them and i used an obd1 dis.
zenon8890
Dec 22, 2005 10:31 PM
JDMJunior
Dec 17, 2005 11:05 AM
NCwhite93integra
Jun 3, 2005 12:47 PM
xstalkrx
May 17, 2003 03:56 AM
Wong Wonder
Feb 23, 2003 02:21 PM
