Anyone have a cel after Fujita SRI??
Just want to know... I have read multiple threads on various sites about other brands either having vibration problems or a cel. Im hesitant to even put an intake on my car.
Dont be i installed my injen sri with no cel many others have as well its the mass flow sensor that gets buggy if it is tampered with during the install just do it carefully you will be fine good luck !
The biggest thing with that was people were not disconnecting the battery for 15 minutes after the install (as described in the instructions). If you do this, you will be fine. Otherwise, your system will not read the mass flow sensor correctly causing the issue.
Install the intake.
Install the intake.
i have the fujita intake, i disconnected my battery during install and it works fine no CEL or problems.
by the way the intake sounds awesome
rs_sexy
Nov 13, 2006 01:34 PM
