FS. 96 VSM Civic Dx Hatchback in OC
The Ride is a 96 VSM Civic Dx Hatchback
Shell has about 65,000 miles
Painted to match molding, lips & side skirts
99-00 Si front end canversion, ctr rear lip
Rollin on Rota Group N’s black w/ red lip rapped in falken zein 195/50/15
Spare roller's Rota Supermesh gold w/ pol lip rapped in falken zein 195/50/15
Interior:
Ctr door panels w/power windows, locks & mirrors all parts new oem
Si cluster only 35,000
JDM Eg steering wheel non-red stitch
ITR shift boot
Ex arm rest
Ac ice cold
Del Sol seats red stripe rip in the driver's left side
Oem rear cargo cover
I have the full interior rollin light weight
Motor:
B16a2 head
AEM 3'' Hybrid CAI
Skunk2 Pro 68mm T.B. port matched
Skunk2 Pro intake manifold w/AEM fuel rail & pressure regulator
Rc 370 Injector's
Hondata I.M. gasket
Mild porting
Itr valves
Port flow springs & retainers
Skunk2 Pro1 cam's
Skunk2 Pro cam gears (6 bolt)
Gsr valve cover w/ 5/8 an fitting's steel braided line's to a baker oil catch can
Fab-Tech header
Skunk2 cat back exhaust
Block:
B20z2
stock oem 9:7-1
Fuel Management:
Odb2 > Odb1 wiring harness
p28 ecu
Hondata s200
B&M fuel pressure gauge
Walbro 255 fuel pump
Rc 370cc injectors
Transmission:
Gsr
Act clutch kit performance street
2nd & 3rd grind mild
Suspension:
Kostom Ground Control kit
600 front 500 rears
Koni 5 ways
Ground control high-hats
Ctr front sway bar
Comtech rear lower tie bar w/sway bar
Gsr brakes disc brake conversion
Itr pro valve
Brembo cross drilled all four corners
EBS green stuff brake pads all four corner's
Skunk2 front & rear camber kit
Megen's rear control arm's
Custom strut bar X cage plus B+C bars
Itr front upper strut bar
Ice:
Pioneer deh-p7700mp deck
Pioneer front and rear speakers
99-00 si tweeter
Extant 3300 amp
Two eclipse 10’s
monster cable 4gauge 500 watt amp kit and rca’s
Priced to sell at $8500
Modified by racer4life at 12:30 AM 1/3/2007
Interior:
ITR shift boot
Ex arm rest
Ac ice cold
Motor:
B16a2 head
AEM 3'' Hybrid CAI
Rc 370 Injector's
Hondata I.M. gasket
Mild porting
Itr valves
Skunk2 Pro1 cam's
Fab-Tech header
Block:
B20z2
stock oem 9:7-1
Fuel Management:
p28 ecu
Hondata s200
Rc 370cc injectors
Transmission:
Gsr
Suspension:
600 front 500 rears
Koni 5 ways
Ctr front sway bar
Itr pro valve
Ice:
99-00 si tweeter
Extant 3300 amp
Two eclipse 10’s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkJavi »</TD></TR><TR><TD CLASS="quote">nice
thank's bro
</TD></TR></TABLE>thank's bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">clean
Thank you
</TD></TR></TABLE>Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer4life »</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboDeznutz »</TD></TR><TR><TD CLASS="quote">
reaallly clean
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores »</TD></TR><TR><TD CLASS="quote">I never really bump for anybody !!!
but that car get a bump !!!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ll1l2l1l2lll »</TD></TR><TR><TD CLASS="quote">bump for.. iono, just because..</TD></TR></TABLE>
thanks guy's
reaallly clean
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores »</TD></TR><TR><TD CLASS="quote">I never really bump for anybody !!!but that car get a bump !!!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ll1l2l1l2lll »</TD></TR><TR><TD CLASS="quote">bump for.. iono, just because..</TD></TR></TABLE>
thanks guy's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpankysEK »</TD></TR><TR><TD CLASS="quote">seen car in person clean as fu*k
thank you
</TD></TR></TABLE>thank you
dynastyboi
Jul 2, 2008 02:55 PM
JuanK20
Northeast (Sales)
10
Dec 26, 2005 11:51 AM
JuanK20
Nov 21, 2005 01:30 PM
JuanK20
Aug 18, 2005 03:39 PM
