rusty bolts.....wat to use to replace?
on my car, like probably most ef owners cars, the bolts are rusty and i want to replace all of them to get a newer look to my car. What bolts do i use to replace them? can i go to home depot or lowes and pick up some bolts and washers to replace my oem ones? has anyone done this? lmk thanx
Im in Ny and we have ACE hardware stores local, they have a great selection of bolts make sure you replace them with grade 8 or 10.9 bolts. Home cheapo and lowes have ****. They are overpriced and never have metric sizes that you need and if they do they are like grade 5 bolts or you have to buy 2 packs of 3 bolts cause you need 4 bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">what bolts are you talking about? where are they just 4 bolts??</TD></TR></TABLE>
like say for your hood or something.
ace is the only place I have found that sells flanged bolts like stock, like the washer part built into the head like
instead of like most bolts from other places
i pieced together some bolts from lowes. cost about $.40 to make one vs. paying $1.50 from an online dealer.
modded 3/16" washer, 6mm-1 washer, and 6mm-1 bolt.
fixed all damaged threads in the process with a clean up tap.
wire wheel x3, almost my entire suspension is off my car ready for lots of new parts n i've been usin a wire wheel to clean off my bolts, look as good as new and it'd save on spendin however much for all new bolts throughout the suspension.
I dont know if there is one, but in California best quality bolts around KING BOLT, bolts will almost never break...high grade
Eastwood makes a bolt "rebuild" kit, comes with a tumbler to clean the bolts, nuts, what have you and a replating kit to give them that new gold, zink look.
Other than that if I were to replace my bolts in my honda I would go order everything from honda.
pliskin679
Sep 14, 2007 06:57 PM
