itr vs gsr crank
Old Dec 19, 2006 | 04:27 PM
Mr HYDE's Avatar
Default itr vs gsr crank
ok spun a rod bearing in my built gsr and need another crank. what would you use? i have pauter rods and 84mm cp pistons. just want some info. i know the itr is weighted a little heavier. should i stick just with another gsr crank or get an itr crank. this motor sees 9grand revs and 30psi of boost
thanks
posted it in here sense i am boosted, think ill get a better response here
Old Dec 19, 2006 | 04:42 PM
Mr HYDE's Avatar
Default Re: itr vs gsr crank (Mr. HYDE)
some advice would help thanks
Old Dec 19, 2006 | 05:28 PM
DRAGLS's Avatar
I would just get the rod journals cut.
Old Dec 19, 2006 | 05:35 PM
NJIN BUILDR's Avatar
I wouldn't go out of my way to find an itr crank.Personally I would get another gsr crank.
Old Dec 19, 2006 | 05:37 PM
Mr HYDE's Avatar
Default Re: itr vs gsr crank (NJIN BUILDR)
i have offers on both right now so i wouldnt be going out of my way to find one. just wondering if i should just stick with an gsr or if theres any benefits of the itr sense i have an offer for both.
my journals have been check and machine shop doesnt want to reuse it. it would have to be cut to far
Old Dec 19, 2006 | 05:43 PM
DRAGLS's Avatar
There is no advantage in using a itr crank over a gsr crank. You will not feel any difference between the two. So go for the cheapest of the two.
Old Dec 19, 2006 | 05:46 PM
Mr HYDE's Avatar
Default Re: itr vs gsr crank (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">There is no advantage in using a itr crank over a gsr crank. You will not feel any difference between the two. So go for the cheapest of the two.</TD></TR></TABLE>
i know i wouldnt feel a difference and they are close to the same price. i already make 650hp just want something that will last. i read some place that the itr crank can handle a little more with the extra weight esp on high rpms
Old Dec 19, 2006 | 05:49 PM
DRAGLS's Avatar
Then go with what you had, if you don't mind paying the extra.
Old Dec 19, 2006 | 06:05 PM
Mr HYDE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">Then go with what you had, if you don't mind paying the extra.</TD></TR></TABLE>
the itr is acutally cheaper then the gsr. price isnt the issue here. advantages of an itr crank is. esp the added weight of the crank
Old Dec 19, 2006 | 06:12 PM
The itr crank will be more stable at sustained high rpms.In a circuit car the itr would be the best choice hands down.I don't think the weight will hurt performance in a turbo drag car.If you can get the itr crank for a good price then give it a shot.
Old Dec 19, 2006 | 06:28 PM
Mr HYDE's Avatar
so an itr may hurt a turbo drag car?
Old Dec 19, 2006 | 06:35 PM
If it was All Motor then the weight would hurt the acceleration.In your case it won't be any issue.
Old Dec 19, 2006 | 07:59 PM
noboostedEGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">If it was All Motor then the weight would hurt the acceleration.</TD></TR></TABLE>
Do you really think the difference would be anything more than negligible?
Old Dec 19, 2006 | 08:38 PM
Mr HYDE's Avatar
Default Re: itr vs gsr crank (noboostedEGo)
what do you mean
Old Dec 19, 2006 | 09:00 PM
sleeprhatch's Avatar
go buy a Pauter crank you balla you. GSR or ITR crank doesn't matter man, bearing clearance and main bearing studs matter.
Old Dec 19, 2006 | 09:29 PM
Mr HYDE's Avatar
Default Re: itr vs gsr crank (sleeprhatch)
lol russ. i just wanted to see if there were any advantages or disadvantages in running a heavier crank in a high boosted car
Old Dec 19, 2006 | 10:30 PM
VRD^don's Avatar
wouldnt u have to buy new rods if u choose to go with a ITR crank.??
Old Dec 19, 2006 | 11:50 PM
doood's Avatar
been there done that
Default Re: itr vs gsr crank (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt u have to buy new rods if u choose to go with a ITR crank.??</TD></TR></TABLE>
no. it has the same stroke as a gsr crank.
Old Dec 19, 2006 | 11:57 PM
VRD^don's Avatar
Default Re: itr vs gsr crank (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
no. it has the same stroke as a gsr crank.</TD></TR></TABLE>
ic..learn something new everyday..
Old Dec 20, 2006 | 12:00 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">ic..learn something new everyday.. </TD></TR></TABLE>
bet you also didnt know the itr crank has two additional counterweights
MrXclusivE
Aug 7, 2009 11:13 AM
Mr HYDE
Dec 19, 2006 11:38 PM
vtecmonster001
Feb 20, 2005 03:53 PM
vtecmonster001
Feb 14, 2005 04:34 AM
bb6
Jun 3, 2003 06:44 PM
