I officially hate brakes
Old Dec 19, 2006 | 04:12 PM
em2ssm02's Avatar
Default I officially hate brakes
ok, i have been working on my brakes for the past few months off and on becuase i havent had much time. anyways, i ended up having bad calipers and didnt' know it so i went through about 4 bottles of brake fluid. so i got some remans, which are a bitch to deal with.
i cant seem to figure out what these problems are i bled them pretty thoroughly, but when i actually drive it the pedal has to go to the floor to stop the car.
new master cylinder, all ss lines, new wheel cylinders, reman calipers.
and another problem is that every revolution of the front wheels it has a lot of friction. its just at one point and you can notice it at slow speeds and also when i tried to turn it when it was in the air it spins freely except for one spot it sticks a lot.
help me
Old Dec 19, 2006 | 04:24 PM
gsxr1k05's Avatar
for the front wheel, maybe a warped rotor?? as for the pedal, maybe a bad booster? also what order did u bleed the brakes in? should be like this.
SiRay13's Avatar
Default Re: I officially hate brakes (em2ssm02)
did you bleed your lines throughly? im sure you did, just had to ask, perhaps you have another bad MC?
Old Dec 19, 2006 | 04:36 PM
Crx Jimmy's Avatar
Default Re: I officially hate brakes (SiRay13)
is the rod that pushes on the m/c / booster adjusted properly? when the car is off and you pump the brakes does it get stiff?
Old Dec 19, 2006 | 04:37 PM
em2ssm02's Avatar
i sure hope its not another bad MC, but ya never know.
yes i bled it thoroughly and yes i know how to bleed the brakes.
Old Dec 19, 2006 | 04:38 PM
em2ssm02's Avatar
yeah when i pump it and hte car is off it gets stiff, but then i turn the car on and all hope is lost
Old Dec 19, 2006 | 04:47 PM
white90rexsi's Avatar
Default Re: (em2ssm02)
Do you have a leak at the brake booster?
Old Dec 19, 2006 | 04:51 PM
em2ssm02's Avatar
i dont think so i mean i pump the brakes a few times, then turn the car on and it sinks.
it actually keeps sinking to about 75%
i havent checked the check valve tho.
Old Dec 19, 2006 | 05:33 PM
em2ssm02's Avatar
bump anyone?
Old Dec 19, 2006 | 05:43 PM
gsxr1k05's Avatar
check all of the above mentioined stuff first before u ask whats next
kfw5045
Aug 20, 2014 10:29 AM
JDMPR
Jul 18, 2009 02:09 PM
FastSS
Jul 8, 2004 12:23 PM
Cow
Mar 27, 2003 04:45 PM
zcpowereddx
Jul 4, 2002 10:35 PM
