92 civic hatch problems
Old Dec 19, 2006 | 04:02 PM
quick87crxsi's Avatar
Default 92 civic hatch problems
I was driving my car to work this past morning, and the car started to spudder then it lost power and wouldnt rev like there was a restriction in the exhaust or intake. So when i got the car towed home it started and would idle fine for a little while fine then it would just cut of like i turned the key off. Pulled the cat off to see if it was clogged but it was fine. Changed the fuel filter and it still does the same thing. It will rev fine then idle but if u let it sit and idle it will eventually just cut off. Any ideas of what this could be??
Old Dec 19, 2006 | 04:05 PM
pythoner's Avatar
This is just a shot in the woods but my grandfathers buick did the same thing when the fuel pump was dead/dieing
poison's Avatar
Default Re: 92 civic hatch problems (quick87crxsi)
I would start by checking the spark plugs, check the distributor cap/rotor, and depending on how old it is I would recommend changing them..
Any CEL?
Old Dec 19, 2006 | 04:08 PM
Default Re: 92 civic hatch problems (poison)
Nope no CEL's. Its wierd cause it will seem like its running fine then just cut off outta no where. I'm leaning toward an ignition problem.
Old Dec 19, 2006 | 04:14 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quick87crxsi &raquo;</TD></TR><TR><TD CLASS="quote">Nope no CEL's. Its wierd cause it will seem like its running fine then just cut off outta no where. I'm leaning toward an ignition problem.</TD></TR></TABLE>
Probably is something worn with cap/rotor, if not the ignitor.
Old Dec 19, 2006 | 05:22 PM
i"ll change the cap and rotor tomorrow and see if that helps.
eg6noise
Mar 9, 2019 11:19 AM
sanders8
10
Oct 21, 2014 02:09 PM
92vtechhatch
Sep 13, 2010 08:15 PM
Mencintaii
May 12, 2008 01:07 PM
Viperlude69
Apr 15, 2005 10:59 PM
