Head Studs
Old Dec 19, 2006 | 03:20 PM
BlackHXCoupe's Avatar
Default Head Studs
Are they needed FOR SURE if you're taking the head apart? I'm changing the head gasket, water pump, timing belt, etc. All that good stuff. Just need to make sure I NEED these before I put it back together.
Old Dec 19, 2006 | 03:22 PM
Luserkid's Avatar
Default Re: Head Studs (BlackHXCoupe)
Uh, without headbolts (or studs) you cant put the head back on Since your not boosted or making serious power you could get away with using the headbolts. But if you plan on doing any big modding i suggest the studs.
Old Dec 19, 2006 | 03:25 PM
hondachris1994's Avatar
u can reuse your old 1's, but some ppl will tell u to get new 1's cause your not supposed to retorque them twice , but I reused mine and I havent had any issues
Old Dec 20, 2006 | 02:15 PM
Default Re: Head Studs (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">u can reuse your old 1's, but some ppl will tell u to get new 1's cause your not supposed to retorque them twice , but I reused mine and I havent had any issues</TD></TR></TABLE>
Alright sounds good, hopefully it holds up till I get my y8 swap.
Old Dec 20, 2006 | 04:01 PM
Bense's Avatar
are you swapping your y5 to a y8?
you know you could just swap cams + rocker assemblies. Or get a regrind for your y5 cam.
Old Dec 21, 2006 | 05:36 PM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">are you swapping your y5 to a y8?
Yea that's what I want to do. But if I can get a full swap for cheaper, then I guess I'd go that route. If I swapped cams + Rocker assemblies wouldn't I still need to change ECU/Wiring etc. to get it running right?
Old Dec 21, 2006 | 06:39 PM
Bense's Avatar
yes, you'd have to change out all that stuff.
You do realize that the y8 only has 13 more hp than the y5, your best bet is to just use the ex trans.
Old Dec 21, 2006 | 09:31 PM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">yes, you'd have to change out all that stuff.
You do realize that the y8 only has 13 more hp than the y5, your best bet is to just use the ex trans.</TD></TR></TABLE>
Yea I know, but I'd be building up the y8 for turbo on the side, meanwhile the y5 goes to **** while I turbo it. That is only if I can find a complete one, if not I'll end up just swapping the cam and rockers
Oh trust me, I already got that down. Converted from CVT Auto to 5spd EX Manual.
Old Dec 22, 2006 | 07:08 AM
teal_dx's Avatar
the D16y5,7,8 motors have headbolts that can be re-used.
The D15b7 & D16z6's have stretch headbolts that should not be reused. (they also cost 3x as much as the D16y* headbolts
Bowl_of_Rice
Dec 23, 2010 12:05 PM
1fastlude1
Aug 16, 2008 06:14 PM
89crxsiVT
May 11, 2007 12:29 PM
the.hamburglar
Nov 12, 2005 07:32 PM
RTW DC2R
Sep 9, 2002 01:58 PM
