Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Mounting ST rear sway on EF/ Which LCA's do I have?
Old Dec 19, 2006 | 03:12 PM
GI8U2racing's Avatar
Default Mounting ST rear sway on EF/ Which LCA's do I have?
I have an 88 CRX HF, but it appears the previous owner may have swapped out the LCA's with 89-91 LCA's, the Koni's are apparently for an 89-91. Anyway, I bought an ST 22mm rear sway bar off of realspeed who had it on 88 LCA's apparently. I assume those holes inboard of the shocks are where a stock rear sway would fit, but not the ST. So how do I mount the ST rear sway on this thing? These are pictures of the left and right side, respectively.
Modified by GI8U2racing at 4:36 PM 12/19/2006
Old Dec 19, 2006 | 03:22 PM
FlyZlow's Avatar
Default Re: Mounting ST rear sway on EF/ Which LCA's do I have? (GI8U2racing)
Those are definitely rear LCA's from an 89-91 Si (or 90-93 DA, but probably not). The non-Si's from those years did not have the holes in the LCA's for the rear swaybar. Not sure how you could rig an '88 bar up to work. People have probably done it, but you might be better off just getting a bar for an 89-91 that bolts right up to those holes.
Old Dec 19, 2006 | 03:35 PM
Well the ST bar is meant for either 88 or 89-91 setups, it's just that the 88 had an adapter kit. I'm sure there is a way I can do this without having to buy a whole new setup.
Old Dec 19, 2006 | 04:04 PM
Lo-Buck EF's Avatar
did the kit come with the 'L' brackets to mount the endlink to the bottom of the shock or lca?
Old Dec 19, 2006 | 08:49 PM
Stefndogg's Avatar
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">did the kit come with the 'L' brackets to mount the endlink to the bottom of the shock or lca?</TD></TR></TABLE>
yup thats the key...u need the "L" bracket that goes from that shiny endlink on the bar to the lower shock mounting bolt
Old Dec 19, 2006 | 09:42 PM
prkiller's Avatar
Default Re: (Stefndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stefndogg &raquo;</TD></TR><TR><TD CLASS="quote">
yup thats the key...u need the "L" bracket that goes from that shiny endlink on the bar to the lower shock mounting bolt </TD></TR></TABLE>
Exactly!
You can see the bracket in this pic for the most part!
Old Dec 20, 2006 | 05:51 AM
Alright, I guess I need to track one down. I hope realspeed still has one. So does that L bracket go on the front of the shock? What keeps it from rotating?
Old Dec 20, 2006 | 07:39 AM
Stefndogg's Avatar
Default Re: (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I guess I need to track one down. I hope realspeed still has one. So does that L bracket go on the front of the shock? What keeps it from rotating?</TD></TR></TABLE>
yup it does...and the only thing that keeps it from rotating is the torque u put on the lower shock bolt that goes through it
Old Dec 20, 2006 | 01:41 PM
the only thing that keeps it from rotating is the torque u put on the lower shock bolt that goes through it</TD></TR></TABLE>
interesting
I think realspeed sounds like he can track one down for me, lemme know if anyone has one just in case he can't come up with one.
Old Dec 20, 2006 | 04:02 PM
Lo-Buck EF's Avatar
youll need 2. one per side
Old Dec 20, 2006 | 04:33 PM
Jaker's Avatar
yup it does...and the only thing that keeps it from rotating is the torque u put on the lower shock bolt that goes through it</TD></TR></TABLE>
The L brackets from my ST 22mm rear bar have a lip welded onto them that catches the side of the shock mount to prevent them from rotating.
Old Dec 20, 2006 | 04:45 PM
Stefndogg's Avatar
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
smart!...did u do that yourself?....i have to look at my st bar and see if it has those
Old Dec 20, 2006 | 08:15 PM
Jaker's Avatar
smart!...did u do that yourself?....i have to look at my st bar and see if it has those</TD></TR></TABLE>
Nope, came that way from ST.
Old Dec 20, 2006 | 08:47 PM
Stefndogg's Avatar
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Nope, came that way from ST.</TD></TR></TABLE>
ah guess mines that way too then lol
CUTTERSPOOL
Suspension & Brakes
Dec 3, 2009 01:46 PM
opeth13
Jun 2, 2004 05:46 AM
viprcr1
Aug 16, 2003 04:58 PM
travis
Jan 7, 2003 11:56 PM
