Very built up turbo H22 engine for sale, not assembled
I ran out of money and can't finish this engine. No expense was spared on the bottom end. It's a pretty complete engine just not assembled yet.
Aftermarket parts (all brand new):
Darton MID sleeve set
Wiseco 89mm 9.0:1 Piston/ring/pin set, coated
Eagle connecting rod set
ARP main stud kit
Clevite main bearings
Clevite rod bearings
Cometic MLS head gasket
Honda parts (all H22A4):
Block (see below)
Crank - used, good, ready to go
Head+cams (used, undamaged, cleaned but not machined)
90% of the rest of the engine parts are there like oil pump, bolts, covers, etc. I have lots of the stock parts so I can supply most of what you need with the package.
This started out as a complete H22A4. It was disassembled and gone through. The sleeves have been installed, decked, bored, and honed for the included pistons. The sleeves have even been o-ringed for extra sealing power. The pistons have been assembled to the rods and test fitted to the block. We got as far as bolting the crank in and the clearance is a little off. My machine shop said the mains need to be align honed to make them perfect. All of the other machine work on the block has already been done. I was going to build it without balance shafts so I don't know the condition of those bearings or bores, they werent machined.
I don't have the distributor or valve cover.
Just the sleeves, pistons, rods, studs, bearings, and head gasket cost me over $1950 to buy. On top of that I have $750 into the block machine work. The engine itself cost me $650.
$2500 OBO for everything. I could use the money so I'm looking to sell right away.
Pics:
http://img163.imageshack.us/im...0.jpg
http://img302.imageshack.us/im...1.jpg
http://img156.imageshack.us/im...9.jpg
http://img221.imageshack.us/im...3.jpg
http://img221.imageshack.us/im...8.jpg
You can reply to the post or email me at cheapmodz@yahoo.com with any questions. Engine is located in Michigan but I can ship it, you pay shipping.
Thanks
ARP main stud kit
Block (see below)
Pics:
Thanks
VisualAutoMotoring
Dec 1, 2008 10:10 AM
VisualAutoMotoring
Performance
Nov 24, 2008 05:45 AM
