3 inch exhaust??
Old Dec 19, 2006 | 11:28 AM
Stillo's Avatar
Default 3 inch exhaust??
would it be wise to bump my exhaust up to a # incher or jus stay with a 2.5 inch...
i am all motor right now and plan on stayin this way
Old Dec 19, 2006 | 11:33 AM
exies's Avatar
Default Re: 3 inch exhaust?? (EG6K24R)
Being all motor, you don't need a 3in exhaust.
Old Dec 19, 2006 | 11:34 AM
Speed Infliction's Avatar
just stay with 2.5 inch and put the money somewhere else. are you trying to gain more power? if so list what you have and we can go from there. you only need 3 inches if you have FI.
Old Dec 19, 2006 | 11:41 AM
B18CJDM ITR's Avatar
Default Re: 3 inch exhaust?? (Speed Infliction)
stay where you are for an all motor set up
Old Dec 19, 2006 | 12:58 PM
Casey's Avatar
Default Re: 3 inch exhaust?? (B18CJDM GSR)
a bit of false info in here.
3" can give power increases in NA applications, even in mild builds. The trade off is noise. ask jdogg about his dyno experience about the subject.
i used 3" on my NA setup, which was the same as bradstards, except i had a 92mm crower billet crank loudest muffled car ive EVER heard
Old Dec 19, 2006 | 02:31 PM
doood's Avatar
been there done that
Default Re: 3 inch exhaust?? (Casey)
92typer also switched from a 2.5'' to 3'' exhaust and gained some impressive numbers
https://honda-tech.com/zerothread?id=1813579
Old Dec 19, 2006 | 02:43 PM
neo_'s Avatar
Default Re: 3 inch exhaust?? (doood)
I've ran a 3" Thermal R&D exhaust on an N/A setup. Only reason I did so is because my header had a 3" collector, but damn it's loud...
Old Dec 19, 2006 | 02:49 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">92typer also switched from a 2.5'' to 3'' exhaust and gained some impressive numbers
https://honda-tech.com/zerothread?id=1813579</TD></TR></TABLE>
It is actually 2.75" , 3" would yield even more gains. But yes, 3" will not sacrafice any power, but you will need to deal with the increase in noise.
Old Dec 19, 2006 | 02:52 PM
doood's Avatar
Default Re: 3 inch exhaust?? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">It is actually 2.75" , 3" would yield even more gains. But yes, 3" will not sacrafice any power, but you will need to deal with the increase in noise.</TD></TR></TABLE>
doh!
how loud is the current exhaust compared to the previous one because my brother had the t1r 65mm and it wasnt very loud at all.
Old Dec 19, 2006 | 02:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">a bit of false info in here.
i used 3" on my NA setup, which was the same as bradstards, except i had a 92mm crower billet crank loudest muffled car ive EVER heard</TD></TR></TABLE>
bump for jdogg!!!!!!
just dont get him drunk hahaha
Old Dec 19, 2006 | 04:21 PM
Pondus's Avatar
I'm thinking about getting a 3" for my 2.1L ITR, I'm sure it will pick up some power compared to a 2.5" Hytech with cat. I have looked at the system that Kteller is offering, it can be ordered with a 14" Magnaflow resonator and Apexi N1 muffler, I'm sure that combo is going to make a bit more noise compared to my current setup.
Or I could wait for T1R to come out with their 3" system, according to AJ sometime before summer... Probably going to be a loud one that as well.
Old Dec 20, 2006 | 12:41 PM
4LugR's Avatar
Default Re: 3 inch exhaust?? (Pondus)
&lt;-- runs 3 inch kteller exhaust... with the magnaflor resonator... but i have a greddy sp2 can.. uber quiet, and that s with no cat.. ( well, a 3inch punched out cat) power gains are impressive.. just make sure you have a header to flow all that out
Old Dec 20, 2006 | 01:09 PM
tartje's Avatar
Default Re: 3 inch exhaust?? (4LugR)
interesting, i was always under the impression that 2.5" is about right for a 1.8 N/A setup, 3" for boost. i always like to be informed, thank you
Old Dec 20, 2006 | 01:39 PM
Bradstard's Avatar
I ran a 3" on my all motor setup with my last ITR. 3" is not too big for NA. There are MANY people out there that are now running 3" on all motor setups. I'm going to run a 3" on my stock motor ITR to see what it will do
Old Dec 20, 2006 | 01:51 PM
Pondus's Avatar
Default Re: 3 inch exhaust?? (tartje)
Well, a couple of us in this thread are not running 1.8l setups, so if it's the hot ticket for that i don't know. But for a 2.0 or larger I'm sure it will free up some additional power. It's on my list of things to get over the winter.
angel07jdm
Aug 4, 2013 08:14 AM
desiromeo812
Jan 23, 2009 09:21 PM
vg7z
Jun 2, 2006 07:01 PM
Derek14
Mar 23, 2004 09:10 AM
GokuSSJ4
29
Aug 3, 2003 05:23 PM
