spinning wheel stud
Old Dec 19, 2006 | 11:23 AM
e jay one's Avatar
Default spinning wheel stud
any ideas how to get my wheel off without messing it up? i went to take the wheel off and one lug nut was sorta hard to turn then it just started spinning the whole wheel stud.
Old Dec 19, 2006 | 11:35 AM
'94civic b16's Avatar
Default Re: spinning wheel stud (e jay one)
if im understanding what ur asking...try lowering the wheel to the ground to break the nuts loose, then raise it to take them off.
Old Dec 19, 2006 | 11:59 AM
e jay one's Avatar
Default Re: spinning wheel stud ('94civic b16)
haha im not that stupid. the whole wheel stud is spinning with the lug nut stuck on it.
Old Dec 19, 2006 | 12:19 PM
be8teensee1's Avatar
cut the jug nut off and buy a new wheel stud
Old Dec 19, 2006 | 01:01 PM
solerizr's Avatar
Default Re: spinning wheel stud (be8teensee1)
torch it
Old Dec 19, 2006 | 01:04 PM
Micha's Avatar
FAILWGN
Default Re: spinning wheel stud (solerizr)
Gonna have to cut it. Sorry.
Old Dec 19, 2006 | 02:00 PM
MasterKwan's Avatar
Default Re: spinning wheel stud (Blu99teg)
You might try snapping the stud off and/or putting some lateral load on it when you try to loosen it to make it grab the hub a little. If you can get at the nut, you might be able to notch and split it with an air chisel and spinner cutter.
If that didn't work, I'd probably try pealing the backing plate up, it's just thin sheet metal and see of I could get something like a vice group on the back of the stud. It's going to be tough no matter what. If I could see the back of the stud, I might try sticking it to the hub with a stick or mig welder.
Then I'd replace the hub once I got it apart because it's toast now. That's why the stud's spinning, the splines are stripped out of the hub.
Old Dec 19, 2006 | 02:48 PM
e jay one's Avatar
Default Re: spinning wheel stud (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">You might try snapping the stud off and/or putting some lateral load on it when you try to loosen it to make it grab the hub a little. </TD></TR></TABLE>
yea i tried that i ended up cuting it off with an angle grinder. im rollin 3 now
Old Dec 19, 2006 | 03:52 PM
super_nguyen's Avatar
make sure when you put a new wheel stud that its pressed in properly or tack weld it.
Eclectia
Jun 16, 2013 11:56 AM
Iloveyourhonda92
34
Jun 9, 2010 11:31 PM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
Ninjaboi_on_X
Mar 16, 2003 07:14 PM
jackal
Apr 25, 2002 11:09 AM
