Hatchback Dyno... Slightly OT
Old May 12, 2002 | 03:14 PM
Ausmith's Avatar
Default Hatchback Dyno... Slightly OT
The set-up:
-JDM ITR Pistons .25” over bore
-Mugen Head Gasket
-3 angle valve job
-ITR valve springs
-CTR cams
-Skunk2 intake manifold
-JDM DC header
-AEM 3” (ITR) intake
-Fluidyne radiator
-Thermal R&D exhaust
-2.5” test pipe
-Chipped ECU
-VAFC
Timing seemed best at 16degrees. Tried 18 with some detonation - I believe that I need some colder plugs. I was using a stock heat range. Fuel pressure was 45psi at atmosphere. The fuel curve was pretty fat all the way through with a very fat spot around 5000 - 5500. No cam gears yet so my tuning was a little limited. We did about 12 runs and got very consistent data. The curves look much like any other GSR/TYPE R with that first hump in the torque curve coming in a little later at 4500rpm.
The torque peaked at 127 wheel at 6000rpm , and peak power was 175wheel at 7600pm. This was a net gain of 35 whp! My basline runs last summer, on the same dyno, was 140whp.
Torque
Power
A/F - notice the fat section around 5k
One of the bay
Has anyone else here seen such a fat AF curve in the 5000 - 5500k range?
Old May 12, 2002 | 03:17 PM
StinkyTofu's Avatar
Default Re: Hatchback Dyno... Slightly OT (Ausmith)
Whats your compression that caused you to detonate, and were you using premium gas?
Old May 12, 2002 | 03:20 PM
Ausmith's Avatar
Default Re: Hatchback Dyno... Slightly OT (StinkyTofu)
Compression is 11.85:1... I was running 92octane. I usually run 93 but I was in the middle of nowhere WI when I filled up and all they had was 92.
When I go back I will bring some 98octane and see how it goes.
Even on 93 I was getting a little detonation at 3/4 to full throttle around 4k rpm.
Old May 12, 2002 | 03:33 PM
sgT's Avatar
sgT
odd, even with ctr pistons i didnt see a lot of detonation with stock '6' plugs
and 91-93 octane.
side note: i was considering a dynapack, but those graphs are so ugly
Old May 12, 2002 | 04:06 PM
Ausmith's Avatar
Default Re: Hatchback Dyno... Slightly OT (sgT)
I agree. I am getting the raw data so I can plot them in Excel
Old May 12, 2002 | 05:28 PM
Dirt's Avatar
Thanks for the invite Clayton. Learned quite a bit and it's funny to watch that whole crowd there drool over the hatchcrap and lurch towards the engine bay as you opened the hood. Sweet ride without a doubt. Can't wait to get a ride in it someday!
I can't believe I suggested to you the VTEC crossover ~4600-4800 rpm. I was so thinking about a GS-R intake manifold and somehow forgot about your Skunk2.
Take care. I saw Sam and his SE-R at Miller Park today. Where were youuuuu?
Old May 12, 2002 | 06:26 PM
ARunto's Avatar
That must be a older dynapack dyno as the new one I've dynoed on has much better graphing.
-Alan
Old May 13, 2002 | 08:01 AM
Ausmith's Avatar
Default Re: Hatchback Dyno... Slightly OT (Velvet Jones)
Aaron - anytime... I just wish it wasn't such a long *** "boring" drive. Next time you'll have to bring someone for the drive!
Actually I really think the best vtec crossover is between 4800 and 5000 rpm on that motor. It is not a super smooth change, but it fits the torque curve.
Where was I on Sunday? I was warm and dry Actually I went to Road America to watch a friend race in ITS.
I'm going racing for sure next weekend in Lake Geneva.
Old May 13, 2002 | 08:07 AM
Ausmith's Avatar
Default Re: Hatchback Dyno... Slightly OT (ARunto)
I'm not sure what version of the software he has. I know he got the dyno last year. It is a Dynapak 3000.
I'm going to make my own plots. I will put them up tomorrow.
Clayton
TPB
May 12, 2006 06:32 PM
b19coupe
Oct 17, 2003 04:50 PM
AzG35
Jan 26, 2003 09:34 AM
Ausmith
May 17, 2002 08:53 AM
RacerXI
15
Jan 30, 2002 10:40 PM
