bought used ignition cylinder w/o key, how to remove tumbler?
Old Dec 19, 2006 | 10:00 AM
pinoyboy204's Avatar
Default bought used ignition cylinder w/o key, how to remove tumbler?
as the title says. bought a used 94 teg auto ignition cylinder from a local wrecker and it had no key. how can you remove the tumbler out if i don't have the key? it says on the manual you need to have it on the "1" position.
please let me know guys!
Old Dec 19, 2006 | 10:33 AM
bostdteg's Avatar
Default Re: bought used ignition cylinder w/o key, how to remove tumbler? (pinoyboy204)
http://techauto.te.funpic.org/...p#tsb
Try that, there is a small pin you have to push out and it lets the tumbler assy, come out. Just like it says pay attention to the order and orientation the parts come out.
Old Dec 20, 2006 | 09:35 AM
Default Re: bought used ignition cylinder w/o key, how to remove tumbler? (bostdteg)
i saw the pin and i pressed on it w/ a small punch. still did not come out.
do you think a locksmith can just do it for me?
Old Dec 20, 2006 | 10:41 AM
bostdteg's Avatar
I would say so, if you take them both switches, they would probably do it for a little bit of nothing, if you dont have the key in the correct position that pin wont come out, if you have a local locksmith try that, i wouldnt think it would be much if you took them both switches and they didnt have to do it in the car.
donut.
17
Jan 11, 2010 07:03 AM
deathblooms4256
Sep 18, 2008 09:57 AM
full Circling
Jun 17, 2005 01:34 PM
coil222
14
Oct 28, 2004 11:36 AM
Hcivic88
Jan 11, 2003 08:44 AM
