t3/t04e 57trim verses 60trim physical outer housing size difference.
Old Dec 19, 2006 | 08:47 AM
jetlude's Avatar
Default t3/t04e 57trim verses 60trim physical outer housing size difference.
Are the outer housing dimensions the same? I want to upgrade from 57trim to 60 on my H22 without doing any farication to downpipe ic piping etc. Will the 57 bolt off and the 60 bolt right on in the same position
Old Dec 19, 2006 | 12:08 PM
ExVtec's Avatar
Default Re: t3/t04e 57trim verses 60trim physical outer housing size difference. (bradboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradboy &raquo;</TD></TR><TR><TD CLASS="quote">Are the outer housing dimensions the same? I want to upgrade from 57trim to 60 on my H22 without doing any farication to downpipe ic piping etc. Will the 57 bolt off and the 60 bolt right on in the same position</TD></TR></TABLE>
To the best of my knowledge they use the same housing...wheels are different..
Old Dec 19, 2006 | 12:12 PM
b18bturbo's Avatar
Default Re: t3/t04e 57trim verses 60trim physical outer housing size difference. (ExVtec)
its identical in housings. same size nothign you have to change unelss you get a 60 trim with like s cover vs a std e or b cover.
Old Dec 21, 2006 | 07:04 PM
jetlude's Avatar
How about the turbine housing? a .63 vs .82 are they the same outer dimensions also?
Old Dec 21, 2006 | 07:12 PM
adseguy's Avatar
Default Re: (bradboy)
Turbine housing will be different if you fgo from .63 to .82
Old Dec 22, 2006 | 03:35 AM
jetlude's Avatar
Default Re: (adseguy)
Will my down pipe still align as I go from .63 to .82, or will it land in a different position when mateing with the .82 turbo outlet?
Nutzurchin
May 20, 2014 01:49 PM
Turbomd
Jan 23, 2008 06:24 AM
EK k kay
Jan 14, 2006 10:58 PM
SEFIxCivic
May 27, 2005 10:56 AM
