205/45/16 drag tires?
Old Dec 19, 2006 | 08:28 AM
AlienKrOZ's Avatar
Default 205/45/16 drag tires?
Are the Yoko ES100 (2000miles used but free) or Prada Spec 2 ($65/each) tires any good for drag racing? I have Yoko H4S on my car now.
Old Dec 19, 2006 | 01:04 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: 205/45/16 drag tires? (AlienKrOZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">Are the Yoko ES100 (2000miles used but free) or Prada Spec 2 ($65/each) tires any good for drag racing? I have Yoko H4S on my car now.</TD></TR></TABLE>
No.
Old Dec 19, 2006 | 01:24 PM
cheapmodz's Avatar
First, get some smaller diameter rims. Then put some BFG drag radials with some side walls on them.
Old Dec 19, 2006 | 01:27 PM
Default Re: 205/45/16 drag tires? (cheapmodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheapmodz &raquo;</TD></TR><TR><TD CLASS="quote">First, get some smaller diameter rims. Then put some BFG drag radials with some side walls on them.</TD></TR></TABLE>
Like so (225/50/15 up front, and 205/45/16 for a full DD set):
Old Dec 20, 2006 | 10:49 AM
EM1OwnerSi's Avatar
i l ike that combo
Old Dec 20, 2006 | 11:39 AM
AlienKrOZ's Avatar
Default Re: 205/45/16 drag tires? (EM1OwnerSi)
how are the falken ziex 512 205/50/15 for the fronts?
Old Dec 20, 2006 | 02:31 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">how are the falken ziex 512 205/50/15 for the fronts?</TD></TR></TABLE>
All the tires your listing are normal street tires. If you are looking for a drag tire you need to find a drag radial. One that has compounds and sidewalls designed for drag racing.
Old Dec 21, 2006 | 04:39 AM
AlienKrOZ's Avatar
Default Re: 205/45/16 drag tires? (nsxmatt)
yes, i know cause im looking for a street tire is not too bad for drag.
Old Dec 22, 2006 | 12:39 PM
civicman02's Avatar
Default Re: 205/45/16 drag tires? (boostincoupe)
boostincoupe, do you have any problems with rubbing in the frontend with that wheel and tire setup? are both wheels 7 inches wide? and how much are you lowered? I love the stance of your civic.
Old Dec 22, 2006 | 03:29 PM
HCivExoo's Avatar
Default Re: 205/45/16 drag tires? (civicman02)
i run falken azenis and they work ok for the street adn track. 200 tread wear and still some pretty good wet whether traction for the rain as long as you have tread. the side walls are reinforced so they don't flex that much under hard cornering whilel on the street. i run a 2.24 60ft in a stock y8 with them
Old Dec 23, 2006 | 08:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicman02 &raquo;</TD></TR><TR><TD CLASS="quote">boostincoupe, do you have any problems with rubbing in the frontend with that wheel and tire setup? are both wheels 7 inches wide? and how much are you lowered? I love the stance of your civic.</TD></TR></TABLE>
Thanks man. To answer your questions...
- It rubs BARELY at full lock (when making a U-Turn, for example)
- They're 15x6.5" wheels up front
- I'm running H&R Sport springs with Tokico Blue shocks. it's lowered ~ 1.75" up front, and 1.5" in the rear
jsull.
Oct 22, 2006 06:53 PM
W.Zero
Aug 21, 2005 11:42 PM
Boostage
Sep 23, 2004 07:47 PM
crazyimport
Sep 5, 2004 02:25 AM
LowFlyin'
Jun 6, 2003 05:14 AM
