d16z6 valve adjustments/specs
I recently purchased a new d16z6 head for my boost application...the seller said that the valves needs to be adjusted...So i was wondering if anyone knows a site i can look valve adjusting up on bc ive never did it before...i know you have to use feeler gaugses...but im not exactly sure on how to adjust them...Thanks guys
check you pm. download the eg file . look under the engine section, then read. you shouldnt have any other questions about your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">.008-.010 intake
.009-.011 exhaust</TD></TR></TABLE>
You should confirm your information before you throw it out there...
The correct spec per the Helm is as follows:
.007-.009 (intake)
.009-.011 (exhaust)
.007-.009 (intake)
.009-.011 (exhaust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">You should confirm your information before you throw it out there...
.007-.009 (intake)
.009-.011 (exhaust)</TD></TR></TABLE>
oh ****...you are right!!!
i was going off memory..
editing first reply...
.007-.009 (intake)
