Check engine light after setting ignition Timming???(code 8/16)
Old Dec 18, 2006 | 09:48 PM
Seatown's Avatar
Default Check engine light after setting ignition Timming???(code 8/16)
My mechanic and I set the ignition timing with a timing light yesterday. I saw the faint red color and though I pretty much had it lined up TDC. Drove it home no problems, today check engine light come on the scares me because I'm about 40 miles away from home. Got it home but what could the problem be? (d15b2 civic sedan automatic)
For the code 16 I got a new main relay, two days ago, I haven't reset my ECU yet though.
Old Dec 19, 2006 | 11:35 AM
Seatown's Avatar
Default Re: Check engine light after setting ignition Timming???(code 8/16) (Seatown)
^bump
Old Dec 26, 2006 | 05:05 PM
Seatown's Avatar
Default Re: (solbrothers)
^fixed, it was the dizzi tdc sensor. Replaced the dizzy and reset ECU both codes are gone.
spens 91 Ef
May 9, 2009 12:09 PM
viciousef9
Jun 14, 2007 03:49 PM
chirp2hrd
May 19, 2006 01:44 PM
hatchinprogress
16
Jan 7, 2005 09:09 AM
aglswapbuffers
Jul 4, 2004 12:45 PM
