86mm type r w/ 1inch dechplate,what timing belt do i run?
Old Dec 18, 2006 | 09:32 PM
SpoolnByYou's Avatar
Default 86mm type r w/ 1inch dechplate,what timing belt do i run?
whats up guys,
im about to buy a type r bored to 86mm,forged pistons/rods, with a 95mm golden eagle crank with a 1inch deckplate welded on top of block. What timing belt can i use? will the type r's fit with the 1inch deckplate? where could i get a custom one,or is another b-series long enough?
Old Dec 19, 2006 | 06:46 AM
Default Re: 86mm type r w/ 1inch dechplate,what timing belt do i run? (SpoolnByYou)
so no one on this forum has a block that has a deckplate on it,or has a dart tallblock?
Old Dec 19, 2006 | 07:07 AM
West Werks's Avatar
You need the adjustable GEM water pump idler for use with a P72 belt, or I believe the Ford Focus timing belt will work which is Gates T-294.
Modified by VenGeanceDrag at 11:10 AM 12/19/2006
Old Dec 19, 2006 | 09:42 AM
Pondus's Avatar
Default Re: 86mm type r w/ 1inch dechplate,what timing belt do i run? (VenGeanceDrag)
A Gates T-294 will work on a talldeck Dart, but that block is just 14mm taller than a B18 block, a 1" deckplate is 25.4mm extra so it will need a longer belt. I have a talldeck and I modified a Meziere idler plate to work with a stock length B18C belt, I contacted GE asking about their adjustable idler plate/water pump kit last year but got the message that it was not available anymore.
The best solution i think is to contact the sleeving company that did the job and ask them what fits. Otherwise you will have to buy and try different belts to find one that fits.
Old Dec 19, 2006 | 01:37 PM
super_nguyen's Avatar
Default Re: 86mm type r w/ 1inch dechplate,what timing belt do i run? (Pondus)
https://honda-tech.com/zerothread?id=1718257
this guy had the same problem, try pm'ing him since i know he got something to work.
Old Dec 20, 2006 | 07:57 AM
they dont have custom belts out for this setup?
Old Dec 20, 2006 | 02:00 PM
soulpwr's Avatar
Default Re: (SpoolnByYou)
Deck plates are gangsta. Timing belt issues however are not. Good luck with your problem. You may wanna try contacting RS machines. I know they do that kinda stuff and would probably be able to help you out.
Old Dec 20, 2006 | 02:21 PM
Pondus's Avatar
Here's a few pics showing what I did to be able to use a stock length B18 belt on a talldeck Dart :
Old Dec 20, 2006 | 05:32 PM
allmotorb20vtec's Avatar
Default Re: (Pondus)
cut a old b series blet ,and install it with the help of some tape and size it up accordingly at you local parts store thats what we did.. the belt was for some nissan truck... i forgot what year..
kingofnothing
Mar 17, 2009 01:16 PM
cyrix12
Jan 6, 2006 12:37 AM
Pondus
Aug 17, 2004 12:27 AM
oldskol
Jun 23, 2004 07:40 PM
EGTeK
Aug 3, 2003 01:37 PM
