Ghetto rig vtec wiring
i just swaped to a z6 motor. im using the dx harness and want to wire up for vtec. on the vtec oil pressure switch which one is the ground(black) and the hot wire(? color).
i guess im trying to say is the wire closest to the distributor is it the ground or positive? so i can run it to the ecu harness and ground the other wire. the solenoid is only one wire so im good on that. thanks
thing is i dont have the plugs that hook up to the oil pressure. so im going to custom make a plug, but i need is some one with a z6 head to tell me if the wire on that plug that is closest to to dizzy is the ground or the hot wire.
