battery relocation. 1991 hb
Old Dec 18, 2006 | 07:55 PM
greenEFSI's Avatar
Default battery relocation. 1991 hb
i want to relocate my battery to the back of my hatch, but i need some tips.
i am going to gut the rear so the spare will be gone and i can mount the battery bracket there, but how do i extend the cables, which ones should i use, and where do i run them from??
Old Dec 18, 2006 | 07:57 PM
EF_9's Avatar
speaker cables???
Old Dec 18, 2006 | 08:07 PM
greenEFSI's Avatar
i dont think they could handle the voltage.. unless they are the huge fatty ones
Old Dec 18, 2006 | 11:42 PM
Boosted_Rex.'s Avatar
Default Re: (greenEFSI)
I have 2-guage power wire from the battery to a Distributor Block (1 to 2 wires) then the two wires run to the fuse box and starter(Starter im using 4-gauge wire). Ground Im running about 1.5 ft of 2-Gauge Wire. Havnt had a single problem for over 2 years.(Cept for AZ batterys leaking)
Old Dec 18, 2006 | 11:47 PM
2poor2tune's Avatar
i just ran a 4 gauge wire from the back to the front with a wire comming of the 4 guage and onto the starter and a smeler one for the fuse box. simple stuff really. and yu can put it where ever you want. on the for if you want. just remember flats happen and i wouldent want to leave my car to go get a spare from a friends house or even my house. hondas getting stollen left and right out here in tucson. oh just send another 4 gauge wire fro the ground strait to the chassis. i used a exsisting ground for the tail light in the center of the back wall of the car
Old Dec 19, 2006 | 06:20 AM
civicandy's Avatar
Default Re: (2poor2tune)
buy a battery relocate kit from summit. then go to sears and buy a smaller battery box, since the one that comes in the kit is the size of a bathtub. thats what i did. if you run the power under the carpet on the passenger side, you will find white plastic clips that hold the wire pefectly. they are between the seat and the door molding along the floor
Old Dec 19, 2006 | 07:46 AM
89efDUSTY's Avatar
Default Re: (civicandy)
there are alot of post already containing the information you need...and you probably dont have to gut it be creative...only cut what needs to be cut.
Old Dec 19, 2006 | 08:06 AM
civicandy's Avatar
Default Re: (89efDUSTY)
you don't have to gut it. just pull the carpet back for a clean install. its very easy. plus if you run it on the pass. side the power comes in by the fuse block and the starter.
Old Dec 19, 2006 | 08:13 AM
Furyof4's Avatar
If you mount the battery inside the cabin you have to use either a sealed battery or sealed box. Filling your interior with hydrogen is not a good idea.
Old Dec 19, 2006 | 09:41 AM
crxpwr1's Avatar
Default Re: (Furyof4)
http://store.summitracing.com/...w=sku
would this work? for a crx
Old Dec 19, 2006 | 09:45 AM
civicandy's Avatar
Default Re: (crxpwr1)
Yes, but. Try to buy just the cables. Go to sears and get the smaller battery box. It will be alot cheaper. And make your own battery hold down for inside the box, because the one in that kit doesn't work for small honda batteries. Plus its junk. I bought that kit and threw most of it away. It will be way cheaper my way.
Old Dec 21, 2006 | 11:42 AM
greenEFSI's Avatar
would i just ground the battery at the reaer of the car and ground the front too?i was thinking of running both positive and negative all the way back. im getting lost...
Old Dec 21, 2006 | 04:52 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
thats exactly what you would do, the car itself will conduct as the ground. CLEAN everything on the surface before you ground it, I've gone as far as getting the wire wheel out to get the paint off, but nonetheless, just make sure its a clean firm connection. The only thing you have to worry about is the positive wire and terminal. It'll be ok, I promise.
Old Dec 21, 2006 | 04:58 PM
mr.coupe's Avatar
Default Re: battery relocation. 1991 hb (greenEFSI)
alright yo i just recently did mine. this is all you have to do.
get some 8 gauge wire (to run from your fuse box to your starter)
about a foot of 4 gauge wire (for your ground)
and about 10-15 ft of 4 gsuge wire (to run from your postive terminal to your started.
DONE!!!
Old Dec 21, 2006 | 05:53 PM
greenEFSI's Avatar
Default Re: battery relocation. 1991 hb (mr.coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.coupe &raquo;</TD></TR><TR><TD CLASS="quote">alright yo i just recently did mine. this is all you have to do.
get some 8 gauge wire (to run from your fuse box to your starter)</TD></TR></TABLE>what is going to the starter? + or -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly what you would do, the car itself will conduct as the ground. CLEAN everything on the surface before you ground it, I've gone as far as getting the wire wheel out to get the paint off, but nonetheless, just make sure its a clean firm connection. The only thing you have to worry about is the positive wire and terminal. It'll be ok, I promise.</TD></TR></TABLE>
thanks for the info
oh yeah do you think harbor freight will sell the wire? or where do i get it?
Old Dec 22, 2006 | 08:33 AM
ComeOnKip's Avatar
I don't see why not. I used 2 gauge stinger power wire...so any audio shop should be able to help you out.
Old Dec 22, 2006 | 09:19 AM
civicandy's Avatar
Default Re: (ComeOnKip)
I grounded my batter in the back, about 1' from the battery box. I put a nice end on the wire and used an existing bolt. Positive goes to the starter. I believe everything in a car always gets the positive signal, and is then grounded.
Old Dec 22, 2006 | 01:54 PM
mr.coupe's Avatar
the positive will go to the starter
Old Dec 22, 2006 | 07:15 PM
greenEFSI's Avatar
will do, i'll post up pics when i get a chnace but will most likely be after the holidays.
c|rop3asy==[]
Sep 9, 2013 11:17 PM
91EF919
Apr 6, 2009 08:27 PM
vesperfx
Audio / Security / Video
Jun 27, 2008 07:34 AM
hb_guy
Apr 9, 2006 06:43 PM
Kasper.
Apr 24, 2002 07:03 PM
