Wheel shaking
Old Dec 18, 2006 | 07:24 PM
gsr-2nr's Avatar
Default Wheel shaking
Whenever I hit 70mph my steering wheel starts to shake. Just got new tires checked to see if they all had wheel weights and they do, my alignment is not off lug's are tight and torqued don't know what else it could be what are your thoughts?
Old Dec 18, 2006 | 07:29 PM
Sumslapper's Avatar
Year 3030
Default Re: Wheel shaking (gsr-2nr)
suspension? axles? cheap tires?
Old Dec 18, 2006 | 07:32 PM
95 integra's Avatar
Default Re: Wheel shaking (sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">suspension? axles? cheap tires? </TD></TR></TABLE>
Sometimes shops dont properly balance the tires when they install them...its more common then you think. It could also be cheap tires. Those are the most likely problems, after that you get into the axles and suspension stuff.
Old Dec 18, 2006 | 07:45 PM
gsr-2nr's Avatar
Default Re: Wheel shaking (95 integra)
Got falken ziex 512's dont think there is any axle damage recently had the inner and outer cv boots replaced and they checked for any axle damage dont think there is any susp damage unless my stock susp is finally going out there seems to be no signs of damage. how would i go about checking if they improperly balanced them take it back in?
Old Dec 18, 2006 | 08:02 PM
95 integra's Avatar
yea, just take it back in and tell them you have a vibration around 70.
Old Dec 19, 2006 | 02:27 PM
martyball619's Avatar
get new axles.
Old Dec 19, 2006 | 02:37 PM
RS'R''s Avatar
Do you get any vibration before 70 mph? I'm having a similar problem... vibration and a slight pull to the right, but it gets better the faster i go. Don't mean to jack your thread, sorry.
Old Dec 19, 2006 | 02:38 PM
r3v da t3g's Avatar
Default Re: Wheel shaking (DC2SiR)
If your tires are off balanced you would feel vibration throughout driving. It is more than likely unbalanced or your rims are bent. Check to make sure your tires are not cupping. I work at Just Tires if you wanna rebalance them or check'em *If you live in so cali*
Old Dec 19, 2006 | 02:40 PM
r3v da t3g's Avatar
Default Re: (Teg'R'S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg’R’S &raquo;</TD></TR><TR><TD CLASS="quote">Do you get any vibration before 70 mph? I'm having a similar problem... vibration and a slight pull to the right, but it gets better the faster i go. Don't mean to jack your thread, sorry. </TD></TR></TABLE>
You need an Alignment, your TOE is off most likely. And get all 4 tires balanced
Old Dec 19, 2006 | 02:44 PM
RS'R''s Avatar
Default Re: (r3v da t3g)
thanks, ill have that done
Old Dec 19, 2006 | 05:26 PM
SlammedDC2teg's Avatar
Just get them rebalanced. Somtimes they dont do it right the first time, or they used to much lube and the tire will shift on the wheel and knock off the balance.
Old Dec 19, 2006 | 05:28 PM
Micha's Avatar
FAILWGN
Default Re: (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">Just get them rebalanced. Somtimes they dont do it right the first time, or they used to much lube and the tire will shift on the wheel and knock off the balance. </TD></TR></TABLE>
Happened on my wifes accord one time.
Old Dec 20, 2006 | 09:16 AM
siksdb8's Avatar
Default Re: (Blu99teg)
check you tire pressure too
Old Dec 20, 2006 | 09:23 AM
akandok's Avatar
if that dont work check your bushings. or even do that before you go through all the trouble. you never know maybe a crappy bushing is doing that...
1994_Integra
Nov 30, 2011 06:05 PM
Acurazor
Suspension & Brakes
Jun 26, 2009 08:47 AM
xxphunkxx
Feb 8, 2008 11:19 AM
VTECcnIT
Feb 21, 2006 06:46 PM
Takumi Fujiwara
Feb 25, 2004 09:17 AM
