b16 swap into eg
hey well im swapping a jdm b16 into a eg hatch i wanted to know what else i needed for this to happen so far i have b16 complete engine b16 hydro tranny shift linkage b16 axles an ls rear t bracket and a ecu what else do i need i was told i could use my stock motor mounts ? please help thanks
C'mon man...there's like 3 threads on this in the first 2 pages.
I'm not usually one to scream SEARCH, but this one can CERTAINLY be found out by searching. One thing I do know is that you can NOT use your stock mounts.
If you don't know how to use it, let me know. I'll see what I can dig up for you.
EDIT: Read this: http://www.c-speedracing.com/h...p.php
Its a GSR install into EG...same principles apply except for IAB wiring.
Also..look at the first stickied post in this forum.
Good luck!
Good luck!
HATCHingMN
14
May 23, 2004 09:31 PM
