light pulsation problem?
Old Dec 18, 2006 | 05:32 PM
civicflow's Avatar
Default light pulsation problem?
OK, I have a weird electrical problem on my crx. When i have my headlights on when the engine is running my interior and exterior lights pulsate. They dim then go back to normal in a fast pattern almost like a strobe light. But with the engine off and lights on it doesn't pulsate. I have no idea where to start. Especially since it only happens when the motor is running.
Anyone have this problem or any ideas what to check?
No codes on the computer either. Thanks
Old Dec 18, 2006 | 05:57 PM
mahatma's Avatar
Default Re: light pulsation problem? (civicflow)
my guess would be a faulty voltage regulator - part of the alternator assembly. that would explain why it only happens with the engine running....
i would try testing the voltage to the underhood fusebox with the engine running, and with just the key "on"....check for irregular readings or fluctuations...?
Old Dec 18, 2006 | 07:36 PM
civicflow's Avatar
Default Re: light pulsation problem? (mahatma)
pm'd you about distributor harness-mahatma
Old Dec 18, 2006 | 07:51 PM
deck1's Avatar
I'm having same issues with my DB8. I think its on the door. You know how there's a sensor that when you open and close your door then your light will turn on/off. I think the door is somewhat loose or the sensor is to sensitive. Hope we'll find the problem-I hate it!
Old Dec 18, 2006 | 07:59 PM
civicflow's Avatar
Default Re: (deck1)
hmm, that is interesting^. i will check that also, thanks
but even my headlights and taillights pulsate too only with the engine on....
Old Dec 18, 2006 | 08:36 PM
deck1's Avatar
Yup! Same as mine! Its hard to explain but I will get to the bottom of it and I will let you know...
Old Dec 18, 2006 | 09:22 PM
cb07's Avatar
When my car was doing that it was the alternator. Put in a new one and now no problems whatsoever.
Old Dec 19, 2006 | 10:03 PM
deck1's Avatar
Default Re: (cb07)
Old Dec 20, 2006 | 06:28 AM
civicflow's Avatar
Default Re: (deck1)
thanks for the replies, i will check out the alternator
Old Dec 20, 2006 | 07:50 AM
civiconfire's Avatar
Default Re: (civicflow)
my old car did that when i put aftermarket sparkplug wires on it... it really pissed me off... i guess it didnt like 10.2 mm wires...lol
Slade.
May 23, 2015 01:12 PM
mussashimits
Jan 1, 2007 09:55 AM
phoenix_iii
10
Mar 15, 2006 06:20 PM
rice4life
Jun 14, 2002 07:34 AM
