D-series with equal length half-shafts
Old Dec 18, 2006 | 05:05 PM
Run Away's Avatar
Default D-series with equal length half-shafts
I'm trying to figure out which D series tranny I can use to have equal length half shafts...
I know the DOHC ZC tranny uses equal-length half shafts.
Problem is that not all D series blocks have holes in them for the midshaft support bearing.
So I'm wondering if there's any other D series blocks with bolt holes for the midshaft support, or any other D series transmissions other than the DOHC ZC with equal length half shafts.
I found this:
http://cgi.ebay.com/ebaymotors...wItem
It's an auto tranny with equal length half shafts on a SOHC non-vtec ZC block. So do all ZC blocks have the bolt holes?
I can't find much info at all on this.
Old Dec 18, 2006 | 05:08 PM
ludesrv's Avatar
Yes but why run one on a D series? They are hard to find and they aren't cheap. Run the Si axles (same as Dx I beleive) and you will never have an issue.
Old Dec 18, 2006 | 05:21 PM
Run Away's Avatar
Default Re: (ludesrv)
Because I can feel the torque steer even with my stock D15B2, and it's annoying.
Old Dec 18, 2006 | 05:26 PM
dr_latino999's Avatar
Default Re: (Run Away)
Other blocks have the hole, I just believe they aren't tapped.
Old Dec 18, 2006 | 07:13 PM
Redline130's Avatar
Default Re: (dr_latino999)
I have a D16Y5 block that has the holes tapped for a half shaft.
Old Dec 18, 2006 | 08:40 PM
SiRay13's Avatar
Default Re: (Redline130)
my d16a6 has the tapped holes, i use the zc tranny with half shafts, no tq steer
Old Dec 18, 2006 | 09:43 PM
silentdork818's Avatar
Default Re: (SiRay13)
I think its the 1.6 blocks that have the holes tapped. The 1.5s have holes too but they arent tapped...just tap the holes on your B2 and throw the ZC tranny on and itll work.
Old Dec 19, 2006 | 06:32 AM
jlicrx's Avatar
Default Re: (silentdork818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">I think its the 1.6 blocks that have the holes tapped. The 1.5s have holes too but they arent tapped...just tap the holes on your B2 and throw the ZC tranny on and itll work.</TD></TR></TABLE>
D15 blocks do not have the holes for the intermediate shaft
Old Dec 19, 2006 | 10:07 AM
SIred91's Avatar
Rainman
Default Re: (jlicrx)
Holy dirty bad gasket motor Batman! ^^
Just go pick up a sohc zc for 400 bucks and get the tranny too....problem solved, and you have an extra motor.
Old Dec 19, 2006 | 05:29 PM
Damn me=stupid...but i couldve sworn my old P08-block D15B had the holes.
oneEg1Tc
Sep 20, 2009 10:58 PM
keep_up
May 29, 2007 05:56 AM
civicprojectPR
13
Feb 11, 2005 08:25 AM
EFin' Kyle
Jul 20, 2004 06:09 AM
